1995 integra Driver Side Noise WONT GO AWAY
Hi ive been expierencing this sound on my front driver side ! It only occurs when my car is really warmed up and sounds like a squeaky noise/ rubber/ metal grinding with eachother. CANT FIGURE OUT WHAT IT COULD BE !? my outer tie bar joint was blown replaced that still noise is there axle boot is torn so i know i need replaced that . Does anyone know any FORSURE ANSWER FOR THIS PROBLEM! please lmk i would appreciate the help! =(
Niether I think but when I slow down it gets louder when I takr off it goes away a little nd when I get o. 2nd starts nd when I gad goes away a little bit
When im on driving at a constant speed you here it too but when my car is cold nd I drive sounds not there intill my car is warmer
Hard to tell from the description of the problem and not being there to hear it for sure, but it could be several things. I know this sounds basic, but did you check your brakes? They're easy as hell to fix and could be the culprit. A worn out/warped rotor can make all kinds of nasty sounds and can even sound intermittent depending on speed. Worth a shot to check.
Can you describe the sound a little more? It's just really hard to diagnose a sound, ya know? You say it sounds rubbery, it could very easily be any number of bushings/joints in your car. It is quickly coming up on it's second decade of service, ya know? Rubber wears out after a while and should be replaced. Maybe a couple pics of whatcha got going on underneath your car suspension/brakes wise might help also.
wolf10851
Jun 26, 2006 11:00 AM
