skunk2 intake ?
Old Jun 4, 2012 | 01:58 PM
ryanmh22's Avatar
Default skunk2 intake ?
so the other day i bought a skunk 2 intake manifold for a good price but like most good things it had its fall back, the intake fits up to my d16a6 block but my a6 throttle body doesnt fit so....anyone have any clue what throttle body i need?
Old Jun 4, 2012 | 02:06 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: skunk2 intake ?
92-95 Civic throttle body will work (stay away from CX/VX). There are older versions that still use the firewall mounted map sensor but the newer throttle body mounted map sensor will work just fine, you just have to pull the plug from the loom to make it reach.
In addition, OBD1 Integra and 92-96 H-series will work. Not sure if 90-91 Integra and 90+ F-series share the same throttle body flange pattern.
PS:
You may want to bang out the firewall a bit because the IACV/EACV will be riding on it (literally).
Old Jun 4, 2012 | 03:59 PM
ryanmh22's Avatar
alright thank you and thats fine but will the obd1 map hook up fine with mine all being obd0?
Old Jun 4, 2012 | 10:43 PM
24TEN's Avatar
PHANTOM MENACE
Originally Posted by ryanmh22
...will the obd1 map hook up fine with mine all being obd0?
Originally Posted by 24TEN
...you just have to pull the plug from the loom to make it reach.
Old Jun 5, 2012 | 07:17 AM
hondaman01's Avatar
bummmppp up
Old Jun 5, 2012 | 07:44 AM
24TEN's Avatar
PHANTOM MENACE
Originally Posted by hondaman01
bummmppp up
What for?
Old Jun 11, 2012 | 04:30 PM
ryanmh22's Avatar
im assuming i also need a fuel rail off a 92-95 civic to fit huh? bc my a6 fuel rail doesnt line up
Old Jun 11, 2012 | 04:54 PM
24TEN's Avatar
PHANTOM MENACE
Yeah you do. I had find that out the hard way too.
EDIT: It's a little late but here's a quick write up I did when I installed mine, hope it helps.
https://sites.google.com/site/24teng...ntake-manifold
Old Jun 11, 2012 | 05:12 PM
ryanmh22's Avatar
thanks for the write up, i hadnt even thought of the throttle cable bracket
Old Jun 11, 2012 | 05:20 PM
24TEN's Avatar
PHANTOM MENACE
Yeah, I had no idea either. That's why I started to document all the stuff. There is one other thing I remember distinctly pissing me off and I had to undo everything after figuring out all that stuff in the link. Take care of this hose first:
It is extremely difficult to install while the manifold is in the engine bay. I couldn't even use the original clamp, I had to switch it up to this:
Old Jun 15, 2012 | 09:27 PM
ryanmh22's Avatar
so what kinda hp are you getting out of your whole set up?
Old Jun 15, 2012 | 11:57 PM
24TEN's Avatar
PHANTOM MENACE
Honestly your guess is as good as mine. I never got around to doing the whole dyno part and I removed the manifold because I got tired of it rattling against the firewall.
Old Jun 16, 2012 | 08:48 AM
Nooch's Avatar
lmao
Old Jun 16, 2012 | 01:29 PM
90 Si Hatch's Avatar
i have a d15b in my 90 si and when i put it in with the Skunk2 manifold i had to beat in my firewall for clearance of the manifold. anyone else have this issue?
Old Jun 16, 2012 | 02:24 PM
24TEN's Avatar
PHANTOM MENACE
Read the post above yours. Better yet, click the link I provided in post #8.
Old Jun 16, 2012 | 02:31 PM
ryanmh22's Avatar
that sucks i beat mine in pretty far so hopefully this isnt an issue
Old Jun 20, 2012 | 06:49 PM
4 years later after i beat my firewall in, i put heat back into my car and the new heater core box wouldn't go into place like it should, so i had to beat it back the other way a bit. only downfall to this intake manifold. so be careful when you do beat in your firewall if you still have heat in your car, you mite damage something!!
EF9Clay
Oct 14, 2011 04:01 AM
90_civic_Si
Nov 28, 2009 09:11 AM
customimports00
Jul 27, 2009 11:56 AM
949
Nov 16, 2008 08:37 AM
