Would a re-man steering rack come with a rack end bushing?
Old Jun 3, 2012 | 09:02 PM
Vagitarian's Avatar
Default Would a re-man steering rack come with a rack end bushing?
Basically I need to replace my inner tie rods, inner tie rod boots, clamps and rack end bushing. All of these parts tally up to $160 for decent quality stuff.
I found a remanufactured steering rack, with inner tie rods and boots and such already assembled
I am unfamiliar with the "rack end bushing" and where exactly it is on the rack, if its inside or out etc.
Im curious if the new reman rack would come with it
Old Jun 3, 2012 | 09:14 PM
90sedan's Avatar
Default Re: Would a re-man steering rack come with a rack end bushing?
The rack-end bushing is basically internal as the passenger side inner/outer tie rods and boot need to be removed for replacement. So the bushing should be replaced with a new/reman rack.
If the reman rack is a good deal, go with it.
Old Jun 3, 2012 | 09:51 PM
Vagitarian's Avatar
ya its a good deal, Im trying to find a tutorial on "adjusting" the gearbox after putting a new rack in if I go that route, tyson talks in many threads about adjusting it after doing the rack end bushing. But I cant find any info on that.
Could I simply drop my old steering rack, and install the new one, or would I need to mark anything to keep its position, or put anything in a certain position while reconnecting the new rack? Im doing new outer tie rods aswell
Old Jun 3, 2012 | 09:56 PM
90sedan's Avatar
The replacement rack should be adjusted, i would put it in and test drive before making any adjustments.
You will most definitely need an alignment. You will need to get the tie rods adjusted as close as possible enough to drive to a shop.
Old Jun 3, 2012 | 10:10 PM
Vagitarian's Avatar
Oh yeah definetely getting an alignment
They list 2 reman steering racks on rockauto.com
Only difference is one say inner thread M12 X 1.5 and the other is M12 X 1.25
What are they referring to and how can I be sure Im ordering the right one?
Old Jun 3, 2012 | 10:34 PM
cjmcleod's Avatar
thread pitch
Old Jun 3, 2012 | 11:24 PM
ChokolAwt's Avatar
to adjust it you just have to loosen the locking nut, turn the adjustment nut till it's tight, then back it off a half turn, then tighten the adjusting nut. it made a helluva difference in my rex. highway driving is so relaxing now.
Old Jun 4, 2012 | 06:32 AM
91EFH22's Avatar
Do you have pictures of said adjustment?
Old Jun 4, 2012 | 07:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
You can use a large channel lock to get the 40mm jam-nut loose. Otherwise the Honda tool costs like $30. It's best to do this while the rack is still off the car because you can't fit a torque wrench on the adjuster nut once the rack is installed. The procedure goes like this:
- center the steering rack (extremely important if you have Si variable rack)
- loosen 40mm jam nut
- tighten & torque rack-guide-screw to 4ft/lbs
- back off rack-guide-screw 10-15 degrees (that's not very much)
- tighten the 40mm jam nut
Old Jun 4, 2012 | 07:59 AM
Vagitarian's Avatar
Which one would my RHD ef7 have?
Old Jun 4, 2012 | 08:32 AM
91EFH22's Avatar
You have a RHD EF? PICS!!!!
Old Jun 4, 2012 | 08:46 AM
Vagitarian's Avatar
maybe after I figure out which rack option I need to buy
Why would they list 2 racks for my car
M12 X 1.5
M12 X 1.25
Old Jun 4, 2012 | 08:49 AM
91EFH22's Avatar
Pics or GTFO! Lol, my guess would be between the Si and all other models? That or maybe a yr difference. Doesnt seem like it would matter seeing as youre buying the whole rack.
Old Jun 4, 2012 | 08:53 AM
94eg!'s Avatar
#1 Super Guy
Loved
Does rockauto carry parts for RHD cars?
Old Jun 4, 2012 | 09:13 AM
91EFH22's Avatar
Not that im aware of. Isnt it a strictly US based company?
Old Jun 4, 2012 | 09:42 AM
Vagitarian's Avatar
Ya they have SOME rhd specific parts. They list 2 steering racks, and they are in the UK, but they list 2 different versions.
http://www.rockauto.com/catalog/moreinfo.php?pk=3185736
http://www.rockauto.com/catalog/moreinfo.php?pk=3211179
I cant really link to rockauto but if you go to rockauto.com, under 1989 crx si 1.6L and click steering and completel rack and pinion, both RHD rack options appear
Im stumped on which to order and want to order TODAY
Old Jun 4, 2012 | 09:47 AM
91EFH22's Avatar
I cant help you there, unfamiliar in this area.
Old Jun 4, 2012 | 04:20 PM
CiTo BuilT's Avatar
You may also have to center the rack or if it comes marked double check it
If not the steering wheel will turn more to one direction than the other
Stea
20
Jul 10, 2021 07:14 PM
sumdewd
Jul 4, 2012 10:52 AM
Vagitarian
Jun 5, 2012 11:04 AM
blasterman87
Jan 17, 2010 06:13 AM
EZ$$EF
Jan 7, 2008 04:07 PM
