Got a question>>>
Old Oct 14, 2002 | 06:40 AM
SS RRR's Avatar
Default Got a question>>>
NooB here w/ a question...
Here's the situation.. I was at the local hangout and see a late model Civic, has a 2 step studder box, 2 fuel injectors per intake runner and is running 60psi of fuel at idle and is on BFG radials.
There is no turbo and the owner claims there is no spray (nothing visible.. was wondering if he could've been hiding it in the intake tube).
People from around the car start saying the car has dynoed 290hp to the wheels and has gone 12.2's. Both of these feats have been allegedly accomplished on motor (supposedly the motor is a built stroker). Car has full interrior. It has a Vtech valve cover yet the owner claims it is the stock motor and went as far as to read off the block ID number located below the left most exhaust port.
When he started the car it sounded tame. No lope of any kind. It did have cam gears though.
He and all the people who were w/ him were talking a mad game but I had no money to run him so I stayed quiet.
Why would he need so much fuel and two injectors per runner if he was running all motor?
Please enlighten if at all possible.
Thanks
Old Oct 14, 2002 | 06:46 AM
EP3_05's Avatar
Default Re: Got a question>>> (SS RRR)
290 whp all motor is tough especially on a small motor like our honda motors. I have seen some heavily built 2.0L Vtec(CrVtec) motors putting close to 250 to the wheels but never anything as high as 300 all motor. Maybe one of the big name all motor cars on drag racing circuit might be pushing that high but I don't think any honda all motor streetcar has put down the kind of numbers you are talking about. Someone correct me if there is a street car out there putting out 290 hp to wheels all motor. He might be on the bottle.
Old Oct 14, 2002 | 12:30 PM
Timmah!!'s Avatar
Default Re: Got a question>>> (91civic)
Not without some kind of an idle lope...He had to have has nitrous...Was it a stock throtle body size???
That motor sounds like a ticking time bomb...
Old Oct 14, 2002 | 12:39 PM
ricodemus's Avatar
I agree I haven't seen a dyno over like 240 all motor. Maybe a 86mm bored crvtec running some high compression and some good cams could do it, but it would never be the "stock motor". Since you said late model, the best bet is that it was a b16 which I highly doubt can hit 300 hp all motor. I say you run him, I'm curious of this setup.
Old Oct 14, 2002 | 01:28 PM
SS RRR's Avatar
Thanks for the replies.
I won't be able to run him this weekend. I'm going to try to run him the Friday after next. :shakeshead:
azroth,
I'm not sure if the TB was stock or not. Didn't notice.
Old Oct 14, 2002 | 01:38 PM
Brandon Chun's Avatar
He's pulling your leg, either hes on some juice or he is not making that much NA
Old Oct 15, 2002 | 01:27 AM
SS RRR's Avatar
Default Re: Got a question>>> (Brandon Chun)
Thanks again...
Here's another question since y'all have been so helpful.
Is it possible for a built N/A Vtech motor to be in the low 12's in a full interrior car?
Most everything I've ever seen at the track the car was stripped out and in the low 13's to high 12's.
Thanks again for any replies.
Old Oct 15, 2002 | 04:04 AM
keithv's Avatar
was it a late model coupe or hatch? either way, he'd have to lighten the hell out of it to run 12.2s on a NA motor (b/c i don't believe the 290hp NA statement).
Old Oct 15, 2002 | 10:10 AM
spiceisler's Avatar
Default Re: Got a question>>> (Matthew)
Let him show you the dyno sheet! <U></U>
Seeing is believing
hatche1
May 10, 2011 04:52 PM
FW_EJ8
Jan 30, 2010 12:39 AM
d_SUPAl1l
May 3, 2006 05:07 PM
IntegraPrez
Nov 1, 2005 01:48 PM
jDMJeRk
Jun 8, 2004 11:24 PM
