obd2b M&W Install questions
Old Jun 3, 2012 | 03:41 PM
93supercoupe's Avatar
Default obd2b M&W Install questions
Edit
the tach on 99eks come from pin a19 on the ecu.
If i connect the tach output from the MW to the harness side of a19, i get nothing.
If i tap a21, where the output signal is for the MW, i can get the tach to show idle, but anything above 3k, it jumps and falls.
Anyone know how to get a 99-00 ek/teg to have the stock tach work with the pro10?
Old Jun 4, 2012 | 07:56 AM
Default Re: obd2b M&W Install questions
Any help?
Old Jun 4, 2012 | 09:08 AM
b18c1Monster's Avatar
Wire it like stock. The tach output from the m&w does not work for stock cluster. Only aftermarket tachs and shift lights
Old Jun 5, 2012 | 01:01 PM
any other help?
Old Jun 5, 2012 | 01:24 PM
jdm inc's Avatar
give tony a call! hell be able to help!
Old Jun 5, 2012 | 01:37 PM
i did. He wasnt too sure on the matter.
Old Jun 5, 2012 | 01:39 PM
I guess ill deal with it when we start the car. I just wanted all the wiring finished up before it hit the rollers. But i guess wiring in the tach after its tuned wont kill me.
Old Jun 5, 2012 | 02:25 PM
jdm inc's Avatar
i just taped mine into the dizzy i have a obd 2 dizzy too. my stock and aftermarket tach works
Old Jun 5, 2012 | 04:24 PM
Same here. But if u disconnect the tach output from the dizzy everything will still work
Old Jun 5, 2012 | 04:26 PM
Originally Posted by 93supercoupe
any other help?
I told u. Just leave the tach wired as stock. I had to do it also
Old Jun 5, 2012 | 05:06 PM
does the stock tach still work if i dont wire it to the mw output?
Old Jun 5, 2012 | 05:07 PM
and just to clarify, 99-00 EK and Tegs dont get there tach signal from the dizzy like all other years.
They get it from the ECU.
Old Jun 5, 2012 | 05:13 PM
SPOOLINmatt's Avatar
yes, you said the ECU gives the stock tach its signal, well, if the ecu didn't see an rpm signal, i dont think it would even fire off the car.
Old Jun 5, 2012 | 05:19 PM
it does in OBD2b form. But i dunno if the OBD1s have the same output. and the wire that is the tach output for the obd2b is where the m&w gets wired into, so its no longer attatched to the car harness.
I gotta look at the harness again, i have a feeling im looking at the wrong pin.
Old Jun 5, 2012 | 10:53 PM
Mike Lowwryyy's Avatar
This is for an OBD2 to OBD1 conversion, but might still have some helpful info you could use to figure out your problem.
https://honda-tech.com/forums/showth...hlight=a21+a25
Old Jun 6, 2012 | 12:44 PM
thanks for posting that up. It actually confirms alot.
Old Jun 16, 2012 | 10:15 AM
ttt
streetrider002
Aug 8, 2011 11:57 AM
eljah0426
Mar 14, 2011 05:59 PM
Fatcobra
Apr 17, 2007 05:20 AM
JuggerNuts
Jun 18, 2006 07:35 PM
B18c1_EG
Apr 8, 2003 04:21 PM
