Semi built gsr untuned drivable?
Old Jun 3, 2012 | 02:15 PM
ceearexx's Avatar
Default Semi built gsr untuned drivable?
I got a semi built gsr with hondata s300 on a p28.
It has 12:5:1 COMPRESSION WITH CTR PISTONS SUPERTECH HEAD PACKAGE BLOX STAGE 2 CAMS TYPE R MICROPOLISHED CRANKSHAFT TYPE R RODS BOLT ONS SKUNK 2 MANIFOLD SHORT RAM INTAKE BDL FUEL RAIL AND REGULATOR 440CC INJECTORS WALBRO FUEL PUMP BDL 70MM THROTTLE BODY MSD IGNITION AND SPARK PLUG WIRES NGK SPARK PLUGS TRI-Y RACING HEADERS ALUMINUM COMPETITION RADIATOR MISHIMOTO RACING THERMOSTAT HONDATA S300 ON A P28
it was all just put together at once i wanted to know if it is safe to drive it at least to a tuning shop?
Old Jun 3, 2012 | 02:25 PM
cjmcleod's Avatar
Default Re: Semi built gsr untuned drivable?
usually you can find a basemap online that's at least pretty close to your setup.... just get a good basemap and then you can drive it to the tuner just be gentle lol
Old Jun 3, 2012 | 02:51 PM
JustOneOrTwoPosts's Avatar
I would just spend a little bit of cash and tow it to the shop. Unless you found someone with the same exact setup, I wouldn't trust running untuned or off a "close" basemap and drive on my newly built engine. But that's just me. You should contact your tuner and ask for his opinion. He might have/create a map for you to drive there.
soslodelsol
May 2, 2006 11:30 PM
bigz187
Mar 19, 2006 06:28 PM
92slowvic
Aug 20, 2004 05:41 AM
HYBRID_H@TCH
Mar 11, 2004 07:52 AM
