is there such thing as a too small turbo?
i got a b16a and plan on using a ihi rhb5 turbo on it. they are kinda small turbos and since i've got it some people have been telling me that it wouldn't be good on a b16a considering that it revs high and has vtec. something like it will overlap at high rpms cause the turbo is too small. i know it spools fast but will i not get anypower from it at high rpms. or will it even take away power at my high rpms.
if you can find a compressor map for the turbo on the left side is the surge limit, basically if you make more power than a turbo can flow it kinda cavitates like a boat propeller when spun too fast... doent make power and the turbo wears out quickly... I would go for a bigger turbo...
