Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
my hood vent...or at least trackside bbq
Old Jun 2, 2012 | 07:12 PM
dbang003's Avatar
Default my hood vent...or at least trackside bbq
picked up a new hood so i could mess with some venting (didn't want to cut up my cf hood since it's in decent shape). threw some spray bomb on it today and bolted it up. at any rate i'll be able to grill up some steaks on it!
going to take a drive tomorrow to get some data.
Old Jun 2, 2012 | 08:52 PM
essex's Avatar
Default Re: my hood vent...or at least trackside bbq
looks great
Old Jun 4, 2012 | 08:45 AM
VTECIntegra9's Avatar
Needs a lid to keep in the flavor.
Old Jun 4, 2012 | 08:47 AM
Black R's Avatar
25 Year Member
Why mesh tho?
Old Jun 4, 2012 | 08:56 AM
Robin6's Avatar
Do you have a lip at the leading edge? You may be scooping up air into the engine bay if not. Not sure if this is what you were after.
Old Jun 4, 2012 | 10:41 AM
rice_classic's Avatar
That would go great with my diamond plate sunroof plug!
Old Jun 4, 2012 | 06:32 PM
dbang003's Avatar
i did the mesh because i thought it would be better than a big hole with no kind of covering. in retrospect i wish i would have tried to copy some of the others i've seen where the back edge curls down. i could just take out the mesh, square off the rear corners, slice down the sides a few more inches and curl the rear edge down.
leading edge is just flat right now. wanted to see what it would do as is and planned on adding a lip at the leading edge, but i might just do what i stated above.
didn't seem to aid in cooling at all...maybe i'll have to go back to a ghetto spacer on the hinge setup :-P
Old Jun 4, 2012 | 11:30 PM
dirty19's Avatar
Ridin Dirty in Cali
Through trial and error comes success.
Looks good, just have to play with it a little to make it more functional.
Old Jun 5, 2012 | 05:53 AM
Robin6's Avatar
You would need to create a low pressure area behind the leading edge
to allow the air flowing over the hood to "pull" air out from under the
hood, otherwise its not doing much with just a hole in your hood.
The lip "down" in the trailing edge will only help if the leading edge has a "up"
lip as they work in tandem.
The hood spacers do work for cooling if you are having over heating issues.
Old Jun 5, 2012 | 08:17 AM
dbang003's Avatar
i was thinking i could get away with lipping down the trailing edge because of what others have done. i thought the slope of the eg hood would count as a lip on the leading edge or maybe i have my opening too far back to utilize the shape of the hood. thanks for the input. i'll keep messing with it. fyi, the pic below is what i was going off of for curling down the trailing edge.
Old Jun 5, 2012 | 08:51 PM
smokin rubber's Avatar
the vent will also work best if you seal the area around the sides of the radiator and up in front of it to create a high pressure in front of it and hopefully high pressure through and behind it, this air then flows out the hole.
Old Jun 6, 2012 | 07:24 AM
dbang003's Avatar
That's definitely on the list. I am making 1 change at a time so that I can see what helps/hurts. Then u can share and maybe help someone else out. I already started cutting out some foamcore board to layout ducting and blockoff plates.
Old Jun 10, 2012 | 12:47 PM
Int3graz's Avatar
cool so far interested to see your final design
Old Jun 10, 2012 | 05:36 PM
dbang003's Avatar
i'll post pics and results when i change it up. for now i moved on to getting the most air directed thru the front, so i'm working out what i need to box in the front and duct everything behind the bumper. will most likely make everything out of abs plastic since it's pretty durable and easy to work with.
here's a pic of the foamcore templates for the front of the bumper. it was too hot out to work on any of the other ducting :-P
Stinkycheezmonky
71
Dec 20, 2013 05:24 PM
BMO98GSR
Apr 7, 2010 08:55 AM
s2krazy88
Honda S2000
Aug 21, 2007 06:50 PM
98or00gsr
Mar 13, 2007 09:42 PM
EL'ation
Feb 19, 2003 05:54 PM
