ED to EF Headlight Question
Old Jun 1, 2012 | 08:39 PM
Beeean's Avatar
Default ED to EF Headlight Question
Just picked up my EF9 front end conversion from Moshi Moshi Motors in Gardena, CA. (Amazing people there btw) But is there anything i have to do to the headlights cause they look like they might be a different bulb. Thanks for the help guys.
Old Jun 1, 2012 | 09:39 PM
crx_si-r's Avatar
Default Re: ED to EF Headlight Question
Yes. Idwally it's best to add in a relay to each side because you will be converting from a 2 bulb headlight to a single bulb headlight. By adding in the relay you will be turning off the low beams when you switch on your high beams. This will cause your bulbs to last longer.
Old Jun 1, 2012 | 09:42 PM
ed7_562's Avatar
I just bought a hid kit that was h4h it was plug and play on mine ...didn't want to deal with all the wiring and relays ..
Old Jun 1, 2012 | 11:12 PM
Beeean's Avatar
alright cause i dont have the ef9 headlight harness.
Old Jun 1, 2012 | 11:53 PM
Beeean's Avatar
im just gonna pick up two harnesses from oreilly tomorrow.
Old Jun 2, 2012 | 12:13 AM
crx_si-r's Avatar
You can do that but you will burn through your h4h light bulbs faster. Trust me. I went through 2 sets before adding in a relay, now it works like its supposed to.
Old Jun 2, 2012 | 12:15 AM
crx_si-r's Avatar
I like my high and lows. Factory function is best in my opinion. Making this harness is roughly 20% the cost of an hid kit
Old Jun 2, 2012 | 12:16 AM
crx_si-r's Avatar
If you need/want a 9006/9005 to h4 (same set up as h4h, just slightly smaller base) conversion harness Lmk.
Old Jun 2, 2012 | 12:25 AM
TeamRedline89Hatch's Avatar
So you are the one bought it huh.. dick. lol jk, I wanted it so bad.
Old Jun 2, 2012 | 01:11 AM
CzrEf's Avatar
Here you go. I did this so I wouldn't cut my harness. Hope it helps
http://www.acura-legend.com/vbulleti...housing-94235/
Old Jun 2, 2012 | 01:18 AM
24TEN's Avatar
PHANTOM MENACE
So he would have no high beams then?
Old Jun 2, 2012 | 05:22 AM
crx_si-r's Avatar
That and he would have to repeat this process every time he replaces a burnt bulb.
Old Jun 2, 2012 | 10:38 AM
tonylovesjdmEF9's Avatar
hehe i see moshi moshi is getting out ther good to know ......well anyways um do wat crx sir is telling you cuz its the safe way of it not just cut the plug for the 9005 on the ef and add an h4 plug and buy the bulbs
Old Jun 4, 2012 | 09:29 PM
Beeean's Avatar
Im not trippin on the relays cause i almost never use my highs. I got them all wired up and everything and they work perfectly fine.
unclematt
Sep 1, 2016 09:39 AM
Yuta
11
Dec 21, 2015 08:17 PM
EFR
Nov 16, 2010 12:07 AM
IMPORTMyth01
15
Aug 4, 2006 07:54 AM
EkcoCRXB16
Sep 17, 2002 07:37 PM
