Brakeline Problem
Old Oct 14, 2002 | 04:02 AM
jdm4life's Avatar
Default Brakeline Problem
What do I do if a flaring nut for my brakelines is too small to fit into the master cylinder?
Old Oct 14, 2002 | 07:01 AM
92sleepR's Avatar
New User
Default Re: Brakeline Problem (jdm4life)
Find the correct nut, cut the old one off, put the new one on, and re-flare the line. Pretty simple
Mike
Old Oct 14, 2002 | 07:03 AM
rob d's Avatar
You need to buy a flaring tool and get the flare nut from the MC you got. Cut your old one off the line and slide the bigger flare nut on to the line. Then you have to use that tool to flare out the line.
Old Oct 14, 2002 | 03:25 PM
jdm4life's Avatar
Default Re: Brakeline Problem (rob d)
Oh I know about all that but finding the correct flaring nut is the problem ...it is for a JDM tegra MC/Booster set ...........update i just finised it and damn i am making a mess on the keyboard w/ all that brake oil ...i went to the junk yard and found the correct flare nut off a 92 integra 4 door and just did what u guyz side..so far so good no leaks. let me tell u the new master cylinder is about twice the size and so is the booster as the stock civic ones. . Brakes so much better too not as much effort.......k peace all thanks for helping
b18 type r
Suspension & Brakes
Apr 21, 2011 06:11 AM
Flip.
Aug 5, 2006 11:25 AM
marshun
Mar 10, 2005 11:10 AM
EGh22aEG
Jul 21, 2003 03:36 PM
sporkcrx
Jan 10, 2003 09:57 AM
