LSV LONGBLOCK NEEDS PISTONS turbo stuff 1000
1000 OBO LSV LONG BLOCK NEEDS PISTONS DUE TO BROKEN RINGLANDS
B16 HEAD :
B16 CAMS WITH STOCK CAMS & GSR CAMS WITH SKUNK 2 CAM GEARS
ITR INTAKE MANI 68MM TB
NEW VALVE STEM SEALS
BWR PURPLE CAM CAP SEAL
HEADS BEEN MILLED
B18B BLOCK: VIN 1203502
EAGLE H BEAM RODS
2 GOOD PISTONS 2 BAD PISTONS THERE SRP/JE
ITR OIL PUMP
ITR WATER PUMP
GATES RACING TIMING BELT
BLOCK GUARD
GOLDEN EAGLE LSV KIT
HEADSTUDS
ACL RACE BEARINGS MAIN AND ROD BEARINGS
F1 RACING STAGE 3 CLUTCH
TAPPED OIL PAN WITH AN FITTINGS
WHOLE SET UP HAS 46 MILES BLEW DUE TO WRONG PISTONS FOR MY TURBO SET UP THANKS TO J2/SRP NEED GONE ASAP THERE WAS NO DAMAGE DONE TO THE HEAD NOR BLOCK LUCKILY IT WAS CHECKED BY MACHINIST
1000 OBO IF I GET 1000 ILL THROWN IN THE TURBO SET UP ALL ITS MISSING IS THE WASTEGATE AND DOWNPIPE
CXRACIGN 50TRIM TURBO
TURBO MANIFOLD
REAL GREDDY BOV
OIL LINES
BIG *** INTERCOOLER + PIPING FOR EG/EK
TXT FOR PICS 2014679221 NOT PARTING OUT DONT WASTE MY TIME UNLESS U GOT CASH
B16 HEAD :
HEADS BEEN MILLED
EAGLE H BEAM RODS
ITR OIL PUMP
ITR WATER PUMP
BLOCK GUARD
HEADSTUDS
TURBO MANIFOLD
REAL GREDDY BOV
OIL LINES
popwars123
Aug 5, 2013 01:20 PM
pearlcfcivic97
22
Nov 28, 2006 06:25 AM
