hard project!
hello!! i want to share with you guys waht i get the other day, and i need advice's! what the hell can i do with these?? any ideas?? the engine its a B16A5 the head its lost
thanks a lot!!
its on a DC2 97's without any interiors, and only with a roll cage..
thanks a lot!!
Just put a ls head on it
But on a serious note.
Strip that car down to the frame and build it up from scratch. There is alot of stuff of that car that needs to be taken care of. that can be a great project if you have the money to fix it up.
I would find a whole donor car to swap a ton of **** out of.
good Luck id love to tackle that.
)Anyway, DO NOT USE THAT BLOCK. Your aluminum sleeve is almost gone in the #4 cylinder and getting bad around the rest of the cylinders. That block has seen better days. If you decide to use it, you will have nothing but problems with coolant consumption.
If I were you, I would get another block and go from there. Get a stock B18C/5/6.
Post pictures of the car man!!! (Hoping it's an ITR
hello! and thaks for your reply and advice, i actually post again with more pic's, and i use this opportunity to tell you that im from chile, iquique, and this is a original JDM dc2, im a lucky guy!! jejeje and its hard to find engines like the b18c block, i will figured that i can sleeve this block, please et me know your experience and advices!!
Its not an "A5 series".. Its a JDM SIR II B16A engine. Its the 170hp version, nothing special. I don't know why its in that car. Most likely because someone pulled the original engine and put that in its place before letting that car rot.
Aqui hay de todo hermano, como te dicen los muchachos, si hay billete ponle camisas nuevas. Si no, pues consiguete otro motor. Ya que ese B16 esta demasiado danhado. Si quieres continuar la conversacion en espanhol mandame un mensage privado (PM). (Las nenas de este foro se ponen todas locas cuando se habla otro idioma.) Mucha suerte hermano!
How did you get the car?
Was it an abandoned racecar? Or did you manage to buy it from Japan?
Seguro que si!!!
Black R
Sep 13, 2004 11:34 PM
