88 crx si swap 91 ls motor...
Old May 31, 2012 | 10:52 AM
3RK's Avatar
3RK
Default 88 crx si swap 91 ls motor...
Hi, i used to be a member in here since 03-04 but i forgot my password and login so i made this new one... but yeah im back into the honda scene now and just recently bought a complete 88 crx si shell and also a DA complete car with motor and did the swap myself... The car starts and just moved it few feets forward and backwards out of the garage no problems. But my question is before when i first start it my odometer works fine and i notice i have a check engine light after it starts for few seconds, then all sudden the odometer just doesnt work any more.. i did a code check and it was my distributor because it was making noise so i changed it to another dizzy i had laying around reset the cables and no more check light but the odometer is not working. I can't even signal, and when turned on ignition i only saw the battery light, no check light, fluid light and etc was on except battery... i havent check anything yet but i wanted to check and make sure and to see if any1 had this problem and how to resovled it... sorry for a long story and i knoe its a old story of swapping ls motor to crx.. but its new to me so please bare with me.. thanks!!
Old May 31, 2012 | 10:59 AM
neophish's Avatar
Default Re: 88 crx si swap 91 ls motor...
sounds like a grounding issue to me, check it out
Old May 31, 2012 | 11:03 AM
3RK's Avatar
3RK
but i wonder where?? all the grounds are connected and bolt on after the swap..
Keelan1394
Jan 28, 2022 06:18 AM
hetas87
Aug 4, 2008 09:50 PM
WrongWD
16
Oct 15, 2004 12:35 AM
egLs20
Sep 21, 2004 04:26 AM
s2kkk
Mar 17, 2004 03:44 PM
