F22A1 To F22A4 Exhaust Manifold
Old May 31, 2012 | 10:28 AM
zmeli's Avatar
Default F22A1 To F22A4 Exhaust Manifold
What Gasket do I need, the EX or LX Exhaust manifold gasket? I am doing the EX Manifold/A-pipe Swap? I was thinking the EX Gasket. What Brand? The factory Nippon or is there a better one out there? 1991 Accord.
Thanks
Old May 31, 2012 | 10:45 AM
GhostAccord's Avatar
Default Re: F22A1 To F22A4 Exhaust Manifold
If it is a 91 I would say that you have the F22A* engine in your chassis. the F22B* engines were found in the 94-97 Accords.
Anywho, I would suggest using the factory gaskets for the exhaust pipe that you are using. For example; if you have an EX manifold and pipes you will need EX gaskets. OEM is good quality. Stay away from the cheap compressed-fibre-material gaskets and stick with the OE style multiple layer steel gaskets.
Old Jun 1, 2012 | 04:35 AM
v4lu3s's Avatar
RTFM
i have always just re-used the gasket that is on the engine.
Old Jun 1, 2012 | 06:36 AM
JarrettL's Avatar
They have different part numbers between the F22A4 tubular manifold gasket and the F22A1/6 cast manifold gasket. The F22A1/6 gasket is 18115-PT0-004(Ishino) and the F22A4 gasket is 18115-PT3-A21(Nippon). I would get the gasket for the F22A4.
I wouldn't reuse the gasket because it is a crush-ring style. It won't ever properly seat again. Sure people get by all the time with repeated use but it's not the right way.
Old Jun 1, 2012 | 12:43 PM
v4lu3s's Avatar
RTFM
I have re-used them on dozens of cars, manifolds and engines. Never had a leak yet.
matter of fact my current 256k mile crx still has the original gasket on there and has been off and on more than a few times.
Rick1t
Feb 9, 2015 05:44 PM
turbotime
Dec 13, 2005 01:08 PM
kb798
May 3, 2004 08:40 AM
tinkerbell
Oct 8, 2002 06:24 PM
