What happened to my transmission?
Old May 31, 2012 | 06:16 AM
ihonda's Avatar
Default What happened to my transmission?
I bought my 02 rsx-s about 4 months ago. It has about 160k miles on it. The transmission has always made a very very light whining noise. Just a about a week or two ago, I start the car in the middle of the day and there it was a noise at idle in neutral, that can be described as kind of a meshy grind but when I applied the clutch the noise went away. So I continued to drive the car as usual. As the days went on, more symptoms started to occur for example, gears started to grind but it wasn't always the same gear, it was random. The noise started to become louder, again it was only when the clutch was not engaged. Then the gears started to kick out. It started with 4th gear then it started kicking out 4th, 5th, and 6th at different times. The gears were becoming more difficult to engage. Then the other day as I was attempting to leave the parking lot and I had it in first gear the car made a loud bang noise, it seemed to have come from the transmission, the idle went down and almost shut off.. this took place simultaneously. Yesterday I had to leave my car at my gf's house because no gear wanted to go in this was right after getting to her house from a 14 mile drive. So I let the car cool down for about 7 to 8 hours I then attempted to drive the car back home, which I was able to make it with little trouble, the drive is highway so I didn't have to change gears too much.
I have done my research by reading through some posts, but none seemed to mention some of the things that have happened to me. I had my suspicions about the throw out bearing but I don't know if that causes all of my symptoms. I want to try and narrow down what my problem is. I will be doing most labor work myself unless it involves getting into the transmissions internals.
Does anyone have any idea as to what my problem may be?
2002 Acura Rsx Type S
Stock
160k Miles
Old May 31, 2012 | 06:37 AM
cetcivic's Avatar
no one wants to hear the truth
Default Re: What happened to my transmission?
If you're not gonna open the trans,then get a replacement w/ lsd or send yours to get rebuilt.
Old May 31, 2012 | 06:42 AM
DANYEM2's Avatar
i think u need to see the parts inside of the transmission. there is gears or maybe seals or gaskets broked, any leaks? change oil at the same time
bro little off,
maybe u know where to buy modified axles from k-motor to d-susp honda?
Old May 31, 2012 | 01:05 PM
Nitrous1024's Avatar
It sounds like the throw-out bearings to me.
Old May 31, 2012 | 05:04 PM
DANYEM2's Avatar
Yes & this is common problem with civic trans, i need change it now.
02sia2's Avatar
it is a throw-out bearing you need a new clutch kit you should replace everything while your in there just because it's a pain to drop the trans so you you don't wanna just replace the bearing then in 5k need a new clutch
Old May 31, 2012 | 06:39 PM
ihonda's Avatar
thanks everyone.. yea im going to drop the tranny tomorrow we'll see how it looks although I also think it its the throw out bearing, i can actually here it spinning
Old Jun 20, 2012 | 06:21 AM
ihonda's Avatar
This was the problem..
broken throw out bearing... installed new one with some Honda Hi Temp Urea Grease now she drives like a baby
Old Jun 20, 2012 | 06:53 AM
Amazing. Now I know.
Old Jun 20, 2012 | 07:05 AM
prelude_h22vtec's Avatar
Good, it wasn't something more expensive!
Old Jun 20, 2012 | 07:19 AM
On average, how often do you change your clutch (in miles or kilometers)?
Old Jun 20, 2012 | 08:51 AM
There is not a specified mileage for when you need to replace your clutch. How you drive will determine how fast it wears, more than the mileage will.
When its worn out, replace it.
Old Jun 20, 2012 | 02:12 PM
I know this. I just wanted to get an average based on everybody else's experience.
Old Jun 20, 2012 | 06:08 PM
poeticfinesse21's Avatar
I had the stock clutch on my ep3 until about 165000 miles and then my throw-out bearing went out too. As long as you don't beat on it too much and change the trans fluid at least once a year or every 15000 miles it should last for a long time.
Old Jun 21, 2012 | 07:31 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I had an accord on 200,000 and I never changed the clutch... but it was a winter ride and I didn't beat on it. Crazy
mychdb2gsr
Transmission & Drivetrain
Jun 7, 2011 04:15 AM
spammy123
Honda Civic (2006 - 2015)
11
Dec 3, 2007 12:11 PM
lude98SH
Sep 8, 2005 06:08 PM
totsie7944
Mar 26, 2005 05:40 PM
