b18c 99si cleaning iac....
Old May 31, 2012 | 04:59 AM
b18c99si's Avatar
Default b18c 99si cleaning iac....
well what excatly will cleaning the iac do? i was told to cleaning it cuz my idol is rough sometimes. i should replace the gasket when i do this rite? should there b any thing else i should do when i do this?
Old May 31, 2012 | 08:26 AM
mann-nyc's Avatar
Default Re: b18c 99si cleaning iac....
You could change the gasket its totally up to you. Basically just spray brake cleaner In thay b!+ch. Pour it out. Before up put it back on give it some time to dry out. Maybe 10-15 Minutes
Old May 31, 2012 | 11:00 AM
EJ8_Man's Avatar
Or you could do a good job and remove the throttle body and the IACV and clean them with brushes and a solvent until they are sparkling clean.
Old May 31, 2012 | 12:55 PM
angryhillbilly's Avatar
take it off, spray the hell outa it with brake parts cleaner. this will ensure that it is not all gummed up inside. and slap it back on there when its dry. if your idol is still lopy then its not cuzza the iac.
luder23
Dec 21, 2012 03:24 AM
JDM_EK_JOE
Mar 3, 2012 07:07 PM
thenext
Apr 19, 2011 09:54 AM
kaluwa3
May 6, 2007 06:13 PM
a1320addict
Feb 11, 2006 08:17 PM
