Where to get F22A Straight cut gears?
Hit up extralargenog on here. He is making a lot of headway with h/f transmissions. Here is a thread he posted not to long ago
https://honda-tech.com/forums/showthread.php?t=3057049
Whatsup man. I have a newly redesigned Sanz set in my car. We had a buy orf 4 sets and got a good deal on them, I can help you, but theyre not cheap and Im not sure what I can get them for you for, but I pmed you
Get back to me when ya can. They are working outr really well.... Especially with the new setup IO have in the car . :O)
The Saenz is bigger and stronger... The ONLY disadvantage is that its ratios are closer than the M"Pro" set (Using the 4:1 Accord final softens the hit of that ALOT) .
I have intimate knowledge of what happens to the "PRO" sets under power in a heavy car that hooks. They dont like it. But, Mfactory is a stand up company and at least replaced the broken fourth gear. My car makes more, is heavier and hooks harder. It gets beat as hard as the car Im talking about. After going for a ride in mine and getting walked on by my car when his set broke, and mine actually lasting all summer at more power in a heavier better hooking car, that PRO set is for sale, so if anyone wants a PRO set with about 1K-1500 miles on it, holler... Hes going Saenz as well, in fact Ill get Mitch to chime in.
Since you are looking for a gear set to fit an F series, Saenz will be your best bet. The Saenz set is a direct fit for this trans and uses the same size 3-4 synchros and slider as the F22. A good upgrade when installing it is to change the 3-4 fork and sleeve to the 98 Accord parts as they are thicker and stronger than the earlier F series.
