Crx B18b1 swap issues
Old May 30, 2012 | 09:17 AM
viva-la-falynn's Avatar
Default Crx B18b1 swap issues
i recently swapped the motor in my 89 crx to a b18b1 it has a edelbrock manifold on it im having alot of issues with wiring and vacum is there anywhere to go for wiring diagrams and vacums diagrams?
Old May 30, 2012 | 09:28 AM
EFinAwesome's Avatar
Default Re: Crx B18b1 swap issues
Best advice given to me I'll give to you. Buy the manual for your car and engine.
Old May 30, 2012 | 09:36 AM
DCRB's Avatar
what are you having problems with? there's like, 3 vacuum lines MAX you need for our cars. if you're using the older obd0 tb theres a map sensor plug, other wise the map sensor is attatched to the tb. theres the pcv line off the front of the manifold, then the fuel pressure regulator which also has a nipple on the front of the manifold, then the brake booster off of the back of the manifold.
what wiring issues are you having
Old May 30, 2012 | 02:37 PM
Jaime 91SiB18's Avatar
I used a Rywire.com jumper w/ o2 subharness and Distributor jumpers.
No wiring needed.
I8ayellowcrayon
Jul 14, 2008 01:18 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
Black Maverick
Jun 1, 2007 08:29 AM
jlhansen
May 25, 2007 03:08 PM
1990hondaHF
Mar 6, 2007 10:00 AM
