Y8 timing tuning
Old May 30, 2012 | 07:55 AM
boosted_D's Avatar
Default Y8 timing tuning
Ok guys,
So I havn't decided for sure yet if I'm going to use neptune or crome pro, it's going to be whatever the tuner is more comfertable with.
I want some knowledge of tuning the timing while it's being tuned, so I can know if what is being done is "safe" or not.
With a Y8 motor the base timing is 12* instead of 16* correct?
Can the software be set to start out timing at 12* base, or does some other funky adjustments have to be made to make this happen?
Also I will be attempting to make low to mid 300's on a 57 trim t3/t4, 8.5:1 c/r stock head and 93 pump gas.
I don't really want to push it past a safe zone, which is why I was thinking I will call it good on whatever I make on around 20 psi, hopefully above 300 whp.
All that said, what would a relativly safe timing number be for 20 psi on 93 pump, assuming the car is making around 300-325 whp?
My goal is to know if a good safe number is lets say 15* advanced, I want to make sure I don't leave the dyno with 22* of timing because it was happy on the dyno with that number, then end up detonating like hell and blowing the motor/ headgasket because of it.
Old May 31, 2012 | 12:34 PM
boosted_D's Avatar
Default Re: Y8 timing tuning
bump................Nobody??
Old May 31, 2012 | 03:35 PM
owneyboy's Avatar
neptune>chrome... be sure you have a tuner close by you who can tune this program.
12 degrees on a base map y7,y8 map add boost tables and all that other stuff you want. have your tuner tune it to maximum break torque or point where it detonates and makes the most usuable pwoer band then tell them to back off 2-3 degrees. y-series engines do not need a lot of timing to make power they actually like less to make the most power. but EVERY ENGINE is different! 300-400whp on a SOHC isnt unheard of nowadays and quite common just make sure your tuner is comfortable with SOHC's and have plenty of expierence with them. i have friends making 450-500whp on 93-94 octane on y8's
nuclidex
Jul 22, 2014 02:03 AM
a1320honda
Engine Management and Tuning
May 9, 2013 11:28 AM
boosted_D
Jun 1, 2012 06:11 AM
THEDirtyDseriesWOOT
Aug 19, 2006 07:40 PM
platinum00
Feb 26, 2005 08:53 PM
