FS: K-***** part out
decided to quit the honda game for now. too busy working to mess with my hondas anymore. many vouches on here and clubrsx. pm me or text me 704-928-5340. thanks.
midori green ek hatchback with k24a2 motor with hybrid racing timing chain tensioner and arp headstuds already installed, k20a2 tranny with lsd, hasport ekk1 mounts, 3inch exhaust with rsr muffler, rsx-s shifter box and cables, charge harness with battery located into trunk with new battery, si wheels with new tires, new powerslot slot rotors and new hawk hps brake pads all around. car was parked because of a broken axle. never had time to fix, started to part out so missing some parts to run and will need to be towed. i have title in hand. probably will start parting everything out of it in a couple weeks if no one interested to buy the whole car as it is. $3000 takes it.
k20a2 head $500
rrc intake manifold cut for a2 z1 head with hondata thermal gasket $400
ips kme cams $800, new cp 87.5mm bore 11.5:1 compression piston for k24 block with k20 head, new brian crower k24 light weight sportsman h-beam rods $900 for pistons and rods
new k-tuned k24 header $500
rdx injectors with clips $120, rsx-s throttle body with k-tuned iacv rotate $100, new hybrid racing tps $80, new k-tuned v2 tps $140, civic type r 6speed shift **** $40, new eg civic omni power clutch master cylinder $100, new eg si brake proportioning valve recommended for rear disk conversion on eg with drum brakes $140
hybrid racing half size radiator with slimfan, hoses, and k-tuned radiator relocation brackets $300
full race pro am eg traction bar $240
new driveshaft shop axles stage 2.9 rated 500hp $600
blox racing drag coilovers 12k front 18k rear $550
ep3 5speed tranny $500
4.7 final drives, one is dc5 type r with new bearing, other is oem ep3 with open differential $100 each
rota slipstream polished 16x7 +40 offset with 205/50/16 bfgoodrich kdw2 tires, bought both brand new,less than 200 miles $900
k20a2 head $500
update:
ek car plus hybrid radiator, rrc manifold, k-tuned header sold.
rdx injectors, k-tuned tps sold.
blox coilovers, dss 2.9 axles pending.
hr tps pending.
ips kme pending.
hr tps pending.
ips kme pending.
JDM.Jay
Aug 31, 2008 02:18 PM
JDM.Jay
Aug 31, 2008 02:16 PM
