really disappointed at toda
Old Oct 13, 2002 | 10:31 PM
fstblkcivic's Avatar
Default really disappointed at toda
everything was installed to specs and when i was breaking in the car and stops movin... exhaust cam snapps
i know exhaust valves are bent.. havent checked yet..
Old Oct 13, 2002 | 10:32 PM
Type R's Avatar
Default Re: really disappointed at toda (fstblkcivic)
cant see pics...
Old Oct 13, 2002 | 10:33 PM
MackSpeed-616's Avatar
if you work on cars as well as you know how to post pics, then no wonder your engine broke
Old Oct 13, 2002 | 10:34 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: really disappointed at toda (BustaNutt-616)
Not good. Will Toda pay for damages or what?
Old Oct 13, 2002 | 10:35 PM
i see them find on my computer
here is link
http://a8.cpimg.com/image/C2/ED/1346...-02000180-.jpg
http://a9.cpimg.com/image/C3/ED/1346...-02000180-.jpg
Old Oct 13, 2002 | 10:37 PM
Reid's Avatar
Global Moderator
Default Re: really disappointed at toda (Emerica)
Why should Toda pay for damages?
It will be nearly impossible to prove that the cams were defective. Installation error will be assumed to be the culprit.
Sorry this happened to you, but you're SOL.
Race parts have no warranty.
Old Oct 13, 2002 | 10:38 PM
Default Re: really disappointed at toda (Reid)
yea i knew that was comin reid..
Old Oct 13, 2002 | 10:39 PM
Evs-One's Avatar
Solbros Owns Me
that's gay. I've also heard a lot about the JUN cams either breaking or shredding timing belts. If the guys at Toda were cool, the least they could do is throw a new cam your way or something.I doubt they'll lose any money
Old Oct 13, 2002 | 10:40 PM
Evs-One's Avatar
Solbros Owns Me
I would think they could help him out considering he just paid who knows how much for a set of cams, and one breaks under normal driving conditions and the engine isn;'t even broken in!b>
Old Oct 13, 2002 | 10:48 PM
CHEETAH's Avatar
sorry to say, but everytime I hear about people breaking cams, whether it be toda, jun, skunk, stock type R or whatever, I tend to believe overtightening on the cam bolt or you used an impact wrench to tighten.
greg
Old Oct 13, 2002 | 11:10 PM
Default Re: really disappointed at toda (CHEETAH)
we used a torque wrench... it was tighten to torque spec from helms manaul... everything was done by the book
Old Oct 14, 2002 | 12:03 AM
Suprdave's Avatar
Sorry, but cams don't just BREAK...
You shoulda tightened them to 20 ft. lbs for the 12mm bolts and 7.2 ft. lbs for 10mm bolts....
Here's the problem...unless you have an inch\pound torque wrench that clicks...it's near impossible to get your torque specs right. I guarantee that your torque specs were wrong on the 10mm bolts without an in\lb wrench.
Suprdave
Old Oct 14, 2002 | 05:29 AM
1 2 NV's Avatar
i dont hear of TODA cams breakin very often. i hear of JUNs, SKUNK2 and CROWER breaking. i hear of TODA cams shredding timing belts. never had any problems with my JUN cams and i guarantee my T belt is on tighter than stock specs. when the motor is running the T belt just moves smooth, no flop at all. ive installed my JUN cams, springs, retainers in 2 different heads and had no problems at all. everyone assumes installation error but its more likely that a bad batch had been sent out of any of these cams. how many of these cams have been made??? a whole hell of alot. seems that when i see posts on any cam breaking i see other posts pop up about the same time w/ the same results.
i always cringe when i hear or see pics of snapped cams, that just sux.
[Modified by hondaatwsu, 6:31 AM 10/14/2002]
Old Oct 14, 2002 | 05:44 AM
Racebrewer's Avatar
Default Re: really disappointed at toda (hondaatwsu)
I'm sorry to hear about what happened and this seems to happem way too often no matter who made the cam.
I'm trying to pin down what goes wrong for so many people.
When you installed the cam did you back off all of the way on the valve adjuster screws?
Also, were the bolts holding the cams tightened in several steps?
Thank you for the info. I hope things work out for you.
John
Old Oct 14, 2002 | 05:47 AM
JPP's Avatar
JPP
Is it possible that the camshaft was dropped or "mishandle" before installation? Because of metal hardness, these thing are very fragile and could of cracked during an impact shock.
Old Oct 14, 2002 | 08:18 AM
EPGONZALEZ's Avatar
Default Re: really disappointed at toda (JPP)
im in the same boat...
Old Oct 14, 2002 | 08:37 AM
Austin's Avatar
Default Re: really disappointed at toda (EPGONZALEZ)
That's not what we like to hear EP...
Old Oct 14, 2002 | 09:04 AM
B2FiNiTY's Avatar
That's no good...
Old Oct 14, 2002 | 11:36 AM
555R's Avatar
agreed greg!
Old Oct 14, 2002 | 11:46 AM
Default Re: really disappointed at toda (C5_ALLMOTOR)
haha thanks c5... ill see what i can do...
Old Oct 14, 2002 | 12:03 PM
tonyxcom's Avatar
Default Re: really disappointed at toda (Suprdave)
Suprdave
This is SO true. Even ft/lbs torque wrenchs with a scale of 0-50 aren't accurate at 10lbs or less.
And if you used a wrench with a scale that started at 10ft/lbs you aren' accurate until about 25ft lbs.
Just ask all the people that have broken valve cover studs.
Old Oct 14, 2002 | 12:12 PM
sleeprhatch's Avatar
could it of been a faulty install? if not that sucks a$$
Old Oct 14, 2002 | 02:54 PM
NW94RS
Guest
Posts: n/a
Default Re: really disappointed at toda (sleeprhatch)
you cant use a torque wrench when installing cams. send it to toda and pray that they help you out,
and how you guys talk about never hearing todas breaking you also never hear about them replacing, I have 2 friends that have/had no clue on what they were doing that had juns break and they sent them back to jun, and they recived replacements with the quickness.
stories such as toda withdrawling their type R from the bidding on ebay and little difficulties that friends have had with them makes ME steer away from that company
BUT above all <U>THIS IS ONLY MY OPINION</U>
im sticking with JUN
[Modified by dc-2R, 11:56 PM 10/14/2002]
Old Oct 14, 2002 | 04:56 PM
Isaac's Avatar
New User
Default Re: really disappointed at toda (dc-2R)
I too have heard of JUN replacing broken cams....
Old Oct 14, 2002 | 05:05 PM
JPP's Avatar
JPP
I am not sure what you mean by this...you definitly can and must use a torque wrench when installing camshafts.
blackk20dc5
Apr 19, 2009 12:16 AM
manoy
Feb 21, 2008 07:12 PM
hytec
Nov 4, 2006 12:41 PM
BlazinITR
Jan 29, 2002 09:16 PM
SpoonFed
Jan 22, 2002 09:05 PM
