♠Θ♠ Mikeb353 DC2 Build Don't Miss out ♠Θ♠
Old May 29, 2012 | 04:08 PM
Mikeb353's Avatar
Default ♠Θ♠ Mikeb353 DC2 Build Don't Miss out ♠Θ♠
Whats up!
Ht, Well this is my first time building a K20 and posting on here. Let me tell you this website has TONS of great information and i will be contacting half of you for information. Well a little history about my integra. I bought this car back in 2008 with 120k. Built a FULLY ls Vtec from the ground up. Well let me just tell you the motor went to ***** after 2 months due to someone taking out my drain plug from my car . Well i bought a daily 4runner and decided to keep the Integra and get back at it. So here i am trying/going to do a k20 build
Old Ls/Vtec Motor
Here is a link to my old B-Series Build
Ls-Vtec Build Thread
First i had to clean up the garage have some room for the Integra to sleep in at night.
Nice out, Took the covers off the Integra started to tear it down.
Bought me a new front bumper and rear bumper.
Removed stock Ls Motor
**** that bitch pin took me 40 min until i gave up and just cut the damn shift linkage
Put that car in the garage, called it a night
Started to remove the dash
Dash it out
Heater core out
No heater core/ clean dash
Removed ABS ( doing a brake line tuck )
Starting to do Harness tuck, Not bad for a first timer :D
Dont worry guys i just tucked it away like this, but i will have all the wires loomed up
Started to mock up the passenger side harness
Did alot for a whole day, going to start to remove fuel tank and headlight get it ready for brake tuck, k20 Hasport Mounts , out to paint . THinking about keeping the same color Frost White
Some Goodies that came in form Summit Racing. All my Necessary brake line hardware. Battery relocation kit
40/40 Prop valve came in
Ordered a ASR Subframe
Thats all for now , will take recent pictures when i come back from World Cup 2010 Paintball Tournament. Hopefully i should have the car done by next season. All input and helpful information will greatly be appreciated.
Old May 29, 2012 | 04:09 PM
Mikeb353's Avatar
Default Re: ♠Θ♠ Mikeb353 DC2 Build Don't Miss out ♠Θ♠
Got some time today started to rip out a couple things inside the car, removed the headliner, seats belts. ABS module. Have to clean up the wiring harness a little bit when i drilled into the firewall to install the brake fittings i drilled into some wires so that needs to some love, Hopefully next week i can remove the sound damping inside and clean up the engine bay, Should be getting my SIR-G Fenders and Side Skirts in hopefully some time next week so i can send the b**** out for paint well here is some progress i did today
Headliner Gone
How the bay sits now
How she sitting now
Inside the cabin, s***s looks clean now hopefully ill have enough wire to loom all of it up
Rear of the car
All the s*** that was removed
Like i said had some time today and took a couple things off, hopefully sat i can get most of my s*** done and get ready for paint....
Mikeb353's Avatar
Wud up Ctv
Let me tell you guys , if you guys want to remove the sound dampening out of you're car go buy some dry ice. I used the heat gun method HOLLY s*** did it take forever just to removed it. s*** was a mess and it smelled so bad. If you do the heat gun method please use a ****ing mask over your face s*** got me sick.. Well i got all the rear dampening removed and cookie'd everything in the rear...
****ing Assualtech.com hasn't yet delivery my usdm spec fenders starting to loose my ****ing patience with them
Mikeb353's Avatar
Got Some goodie In....
Odessy Battery
Battery Tray Holder ( Going to be side mounted)
Brake Lines
Thanks To my Awesome GF i got me a NRG V2.5 Quick release steering wheel
Still awaiting my
k20 Swap Motor Mounts
K-Tune shifter Plate
Old May 29, 2012 | 04:10 PM
Mikeb353's Avatar
Got a update today and some more goodies in
Well i was able to relocate the battery and get it installed still need couple things, Starting to get cold out. Hopefully next weekend i can have the jdm front end here and put the battery terminals in and pick up my doors.
Took me about 30min. to get this bad boy installed, decided to do what seanjohn did drill and tap it, to be honest with you i was surprised it held on with 3 bolts lol...
Received my K-Tuned Shifter Plate
Inovative K20 Motor Mounts 60a Shore
STAY TUNED FOR RIDICULOUS UPDATES
Mikeb353's Avatar
Got some JDM GOODIES received today
The damage, Opened up the package come to find out both of the fenders were heavily dented in. Called the dealer up asap said to shoot him an email with pictures.... Hopefully they can refund me or send me another set :/
Old May 29, 2012 | 04:11 PM
Mikeb353's Avatar
Had some time today and went down to Harbor Freight Got me some tools to get this front end going. Not yet finished but was able to get the T-bar off the usdm rad support and the JDM T-Bar off the ITR Front End. I'm going to wait and get the other Fenders that the Company is sending down before i weld the whole t bar dowm. Got me some strong clamps and clamped it all down for s***s and giggles i bolted everything up to see what it would look like and the fitment.
Not going to lie i was very hesitant about doing this myself, But i read , searched and read until there was no Tomorrow. Anyone can do these front ends just measure , measure , measure and cut and you will be perfect. Ill have the finishing updates some times this week
Mikeb353's Avatar
[CENTER]Got some updates on the whip, been a long cold winter fellas, So had to lay off the car for a bit, Well I got one of my tech from work to help me prep car up for paint. Fixed that dented *** fender, Got me some new doors ( Shaved Moldings) Sent the subframe to get sandblasted, Bought me a k20 Valve Cover with An Fittings.
Picked these doors couple weeks ago, Shaved Integra doors... This will save me some time in the long RUN.
Here is the Fender we been working on, If you guys been following the thread this was the fender that got dented in VERY Badly...
k20 Valve Cover W/ 10-An Fitting with Catch Can
[B][CENTER]Good some goodies coming in this week, got one of them in today
K Series CM2 Harness by chase bay got it for a STEAL
Waiting on some JDM goodies coming from Canada
Mikeb353's Avatar
Finally got some time to do some work on the car, Been super busy with work and tournaments lately. Awaiting for the doors and subframe. Mean while I got the k-Tune shifter plate in. Skunk2 goodies have arrived... FINALLY the 5 lug has arrived as well.... Got started on the engine bay sanding it down and covering up some holes (harborfreight welders suck ) but it gets the job done
For the first time doing a engine bay prep and welding, I think I'm doing pretty good. Will find out on when she's painted
The 5 lug conversion
K-Tune Shifter Plate
Some Skunk2 Goodies
Lower Control Arms
skunk2 Lug Nuts
Mikeb353's Avatar
Finally got my Air Compressor back, Finished welding all the holes in the engine bay. Seam Seal the seams again shaving them down once the body filler dries up.... here is were I'm at right now with the engine bay
Old May 29, 2012 | 04:12 PM
Mikeb353's Avatar
Finally got around to work on the car again, I REALLY want to thank PIMPBAY's CREW FOR ALL THERE HELP PREPPING MY ENGINE BAY. THANK YOU GUYS CANT WAIT TO GET THE BAY DONE. Here are some recent updates were I'm at.....
Inside the cabin, not going to cover all the holes.
Antenna hole welded shut and filled
Driver side door side molding holes welded and filled have to start feather edging it..
Spoiler
Passenger side door and rear quarter panel done
Engine Bay
Again thanks to Pimpbay's Crew for all there help legit cool *** people
Honda Day coming up hopefully i can talk to some of the guys at Ktune and pick a couple things up for the k which should be here pretty soon, then shopping for the tranny and i should have pretty much everything were i want it to be. Deff shooting for this year for the car to get done been a very very long Journey and cant wait to get this car out on the road.
Mikeb353's Avatar
Finally picked up a k24a2 for very good price. Started to clean and gregrease engine, Should have some nice plans for this bad boy! Should have it nicely painted by Sat.
6 hour Drive To pick this bad boy as it stands
Started to degrease and Clean her up
[B]
Whats up Finally all that hard work in the engine bay payed off. Finally got
the engine bay sprayed thanks to Pimpbay Crew for coming down and shooting it for me.
Great crew and fun to be around with. Learned alot of information as well.. Again
Thanks To Pimpbay Crew and all his hard work. Now I will let the picturs speak for them
selfs
Pimpbay Crew( believe one of them was shooting 1st stage primer)
First coat of primer
Sanding
Primer
Old May 29, 2012 | 04:20 PM
vinmotors's Avatar
wow! doin work son!
Old May 29, 2012 | 04:30 PM
Mikeb353's Avatar
last stage, s*** came out awesome, Now i can fully get the engine and suspension put on
Everything came out amazing again thanks Pimpbay Crew
Cell Phone Pictures Sucked, Busted out the Canon Camera Here are more pics of the engine bay
Old May 29, 2012 | 05:08 PM
Mikeb353's Avatar
Originally Posted by vinmotors
wow! doin work son!
Thanks Man!
Old May 29, 2012 | 06:03 PM
elsicario12's Avatar
you build is sick brooo..
good luck building the K20
Old May 29, 2012 | 06:10 PM
DIYKITS@BB4lude's Avatar
Awesome build!! I will be watching this one daily!
Old May 29, 2012 | 06:32 PM
brsteinbach's Avatar
Old May 30, 2012 | 01:43 PM
Mikeb353's Avatar
Thanks Guys! hopefully ill have this done by end of summer ready for spring
Old Jun 1, 2012 | 02:02 AM
composurey's Avatar
looking good
i'm planning to do a front end on my teggy
any good resources that helped you alot?
Old Jun 5, 2012 | 12:30 PM
Mikeb353's Avatar
Again got some time to work on the integra today, Boy Mark also came down last Sat to start getting the body ready for Primer. Still have a long way to go. Today i got the whole underneath of the car Por15'd and Rubberized undercoated (12 cans later)lol. Also got the Passenger side headlight tucked in and loomed up, Well halfway loomed up ran out of loom did not feel like buying more. Got the whole interior rear harness Loomed and sleeved up nicely, Deff thinking about purchasing Cusco 21 Point Roll Cage. Changed my mind about the fuel lines, going to do All A/n Lines from the fuel pump to the aeromotive reg. Keep you update as I go
Ps Brother got a new Guard Dog, We call Him TURBO try out running him....
8 Months Old,Pit
Can of Duplicolor Rubberized Coating, Bought 12 cans
Por 15 Amazing stuff, paint right over rust
Outcome
Bye-Bey Ugly Fuel Lines
Harness
Old Jun 5, 2012 | 12:33 PM
Mikeb353's Avatar
Originally Posted by composurey
looking good
To be honest with you man i just searched and read alot, great info on here ill try to find you the link, Also check youtube out and i think modified mag showed a dc getting a front end as well. I think there two ways you can do it i did the T style or you can replace the whole rad support
Old Jun 5, 2012 | 07:04 PM
composurey's Avatar
well i wanted to do the nose conversion that comes with the hood, fenders, ect, is the nose conversion easier than piecing together the parts and whatever? any hellp?
Old Jun 5, 2012 | 07:15 PM
Mikeb353's Avatar
Hmmm Good Question, All i can tell you is call around my friend, I Pick up my whole Front ( Front Bumper, Rad Support , Fenders , Hood, HID headlights) all for $750. Jdm-online.com. I'm not sure if the same guy is working there are not But i spoke with Nash, Awesome dude he also gave me a good deal on my 5 lug conversion (no Rims)...
Old Jun 5, 2012 | 07:29 PM
Daren73's Avatar
Nice dc build! Love the integra j-spec front ends. Can't wait to see the finished product.
