b16 passing smog?
Old Oct 13, 2002 | 10:22 PM
-16V-'s Avatar
Default b16 passing smog?
I was just woundering how many people out there got there (JDM) b16 to pass smog and if so what did you do before the test.........
One more thing i think the engine that i have is an 1989 xsi and i have a 1991 dx hatch, Now what problems am i going to run into when trying to smog it??
Newer car older engine??? I heard a couple bad things about that...
Old Oct 13, 2002 | 11:20 PM
crxcess's Avatar
Default Re: b16 passing smog? (1991_jdm_sleeper)
hopefully they won't motice its an older motor. if they ask you, lie your *** off!!!
Old Oct 13, 2002 | 11:54 PM
guttedEF's Avatar
Default Re: b16 passing smog? (crxcess)
All I did was replace my cat, did a complete tune-up, and used premium fuel. Passed with flying colors.
Old Oct 14, 2002 | 05:11 AM
SiR Kid's Avatar
New User
Default Re: b16 passing smog? (guttedEF)
Tell them you broke the timing belt broke and the HEAD is an 89, but the engine is originally a 92 or something The head is the only thing that has a date stamp, right?
That should get you off the older engine/newer car thing.
[Modified by SiR Kid, 8:23 AM 10/14/2002]
Old Oct 14, 2002 | 08:27 PM
StorminMatt's Avatar
Probably people who don't live in an 'Enchanced Smog Check II' area (like Sacramento).
Old Oct 14, 2002 | 08:56 PM
incubus's Avatar
Default Re: b16 passing smog? (StorminMatt)
IN Maryland, they don't care if the motor is older than the car as long as the OBD is the same or higher. You could call and ask them if it matters.
Old Oct 19, 2002 | 02:23 PM
CHRIS 1.8's Avatar
Is it true that if you car fails test only, that the next time you have to test only your car, the DMV assigns you to a specific station to go to? I am talking about here in CA.
[Modified by B16A1-EF8, 11:23 PM 10/19/2002]
Old Oct 19, 2002 | 02:52 PM
sitrucjr's Avatar
Default Re: b16 passing smog? (B16A1-EF8)
a few months ago i didnt pass the smog check and the mechanic told me i had 1 week to try to fix my car to get it to pass smog,,,or it would be labeled a gross poluter,,it passed the next test,,,,i live in san francisco
Old Oct 19, 2002 | 05:45 PM
big pete's Avatar
Default Re: b16 passing smog? (sitrucjr)
i passed with a 525HC level
Old Oct 19, 2002 | 10:05 PM
vtec crx's Avatar
Default Re: b16 passing smog? (big pete)
i passed with flying colors and i had ctr cams and type r throttle body
Old Oct 20, 2002 | 02:24 AM
brad.'s Avatar
Default Re: b16 passing smog? (vtec crx)
where?!?! im in pasadena....but you have to go to the ref for the swap...is that what you did? unless you had a hook up
Old Oct 30, 2002 | 12:23 AM
vtec crx's Avatar
Default Re: b16 passing smog? ([626]JDM-b16a-EF9)
you can get the motor ref but i just went to a test only and it passed,i got a gsr motor now and ill smogged it yesterday and it passed,im in city of industry
Old Oct 30, 2002 | 01:44 AM
brad.'s Avatar
and you were running OBD0?
Old Oct 30, 2002 | 08:26 PM
It sounds like you are just lucky. Technically, nobody but the ref can smog a swapped motor. I guess that they just didn't care where you went.
dingusjt
Dec 24, 2003 02:01 PM
CLICC916
11
Feb 15, 2003 03:03 PM
YellowCivic95
Apr 24, 2002 08:54 AM
rexnoir
Jul 18, 2001 07:18 AM
