FL FS: 1999 Civic Si 34,xxx original miles. Various purchase options
I purchased this vehicle from the original owner. The car hasn't been driven or registered since January 2007 and the vehicle has 34,xxx original miles. Yes ORIGINAL! The car was never abused but it just sat under a carport for a little over 3 years. He barely even drove the vehicle due to his current company car and ex military deployments.
I wanted to transform this vehicle into a 450hp weekend car that can double as a show quality vehicle. We started the build by tearing it to pieces to have the body, all jams and engine bay sprayed. The paint work is courtesy of Mike Bigheart.
Fuel Management/EMS
Hondata S300 boost option & P28
Precision 880cc injectors
Walboro HP Fuel pump
Engine:
Original B16a2 motor.
-Stock sleeves
-Race Engineering block guard
-Eagle H beam rods & big rod bolts
-JE 9:0.1 pistons and rings
-Clevite coated race bearings
-Gsr Exh cam
-dual valve springs
-milled head
Transmission:
Original Si transmission with Type R LSD
Absolutely no grinds
Boost:
Precision 6262 billet wheel
PeakBoost FTW a/c compatible
Tial 38mm gate
Suspension & wheels:
Blox Full Bodied Adjustable Coilover System (Tuner series)
Stock suspension is in the trunk
$4,500 as a rolling shell on Si wheels. Keep in mind the car hasn't been driven in over 5-6 years and was professionally painted and would ONLY need a motor swap to be complete. The interior is completely stock, intact, and clean.
$7,500 as a complete running car on Si wheels with the professionally assembled turbo motor. No actual turbo parts will be included unless a deal is worked out. The car will come on stock suspension with the oem ecu unless a deal is worked out. I will show the motor build before the motor is closed back up. No BS here I want the buyer to be 100% confident that the motor and car is what I say it is. The motor is waiting to be assembled with receipts on machine work.
The prices are firm and reasonable. No trades whatsoever.
Build pics can be seen here:
http://www.tamparacing.com/forums/me...-civic-si.html
386.216.5422
-Joe
Fuel Management/EMS
Engine:
-Stock sleeves
-Gsr Exh cam
-dual valve springs
-milled head
Transmission:
Boost:
Tial 38mm gate
386.216.5422
-Joe
boostme1
Apr 6, 2011 04:22 PM
simplsi
Dec 24, 2007 06:59 AM
