fuel gauge problem
Old May 29, 2012 | 12:09 PM
efstunnin's Avatar
Default fuel gauge problem
alright so in my eg sedan the gas gausge in the cluster isnt working properly
i checked all the wiring and everything is in tact
i played with the plug a lil yesterday and it went down to half tank and then went right back up to past full
i even removed the glass and moved the needle down and plugged it back in and it still went up past full
dont know what it is sooooooo if anyone does please help lol
Old May 29, 2012 | 12:20 PM
Former User's Avatar
Default Re: fuel gauge problem
You risk damaging the gauge by moving the needle. Avoid that.
Use a multimeter to check whether the wire that runs from the cluster to the sending unit connector has a short.
Old May 29, 2012 | 12:27 PM
efstunnin's Avatar
already did
it came out good..but there is a bunch of goo on the conector
does that affect anything
Old May 29, 2012 | 12:30 PM
Originally Posted by efstunnin
already did it came out good..
Describe the test that you did and what the multimeter reading was.
That's probably just dielectric grease. Post a picture.
Old May 29, 2012 | 12:35 PM
efstunnin's Avatar
Old May 29, 2012 | 12:36 PM
efstunnin's Avatar
and my buddy was the one that did the test
im not super good at electrical work and he is so he did
what test should be done so i can ask him and make sure he did it right
Old May 29, 2012 | 12:37 PM
Dielectric grease seals the connector from moisture. Don't remove it.
Ask him to describe the test that was done and what the multimeter reading was.
Old May 29, 2012 | 12:40 PM
efstunnin's Avatar
im waiting for a reply from him
what should have been done?
Old May 29, 2012 | 12:42 PM
The proper test is to look for continuity to body ground (=short)
Old May 29, 2012 | 12:44 PM
efstunnin's Avatar
and how do you do that test
Old May 29, 2012 | 12:54 PM
Unplug the sending unit connector on the fuel cover. Set multimeter to measure resistance (Ohms), or continuity if your meter has that feature. Touch one meter probe to the fuel gauge wire (Yel/Wht wire terminal) in the connector and the other meter probe to an unpainted part of the metal chassis.
Old May 29, 2012 | 12:56 PM
efstunnin's Avatar
alright ill try.
Old May 29, 2012 | 01:01 PM
efstunnin's Avatar
one came up as 0.08 and the other came upas 0.00
the car was off..does the key have to be on?
Old May 29, 2012 | 01:02 PM
One what? Do you have a digital multimeter? Are you measuring resistance (Ohms)? What Ohm scale is your meter set to? Or is it auto ranging?
Key off
Old May 29, 2012 | 01:08 PM
efstunnin's Avatar
alright so after testing it i looked at the cluster and the needle went all the way down
then i plugged it back in and it slowly started going up
it hit half tank and stopped for a min
i turned the car on and it went all the way passed full
Old May 29, 2012 | 01:40 PM
This happened when the sending unit connector was unplugged and the key was in ON(II), right?
Only with key in ON(II), right?
After you started the engine, right?
Old May 29, 2012 | 01:59 PM
efstunnin's Avatar
yes as soon as i started the engine the fuel gauge went all the way back up
but slowly
and stopped a lil at the halfway mark
but now its stuck at past full mark
Old May 29, 2012 | 02:08 PM
What's the answer to each of the three questions I asked?
Old May 29, 2012 | 02:13 PM
efstunnin's Avatar
the sending unit was unplugged with t the car off
then the car was still off and i plugged it back in and it started going up
thenwith car still off it went halfway then stopped
then once car was running it went fully back up
Old May 29, 2012 | 02:19 PM
efstunnin's Avatar
and i have an observation question
i was looking at the sending unit and at the plug
the sending unit looks like it has prongs on two of the three ports
the front one closest to the ftront of the car and the middle one and the one by the trunk looks emoty
now looking tat the plug
the one closest to the front of the car is empty and themiddle and back one have the two plugs in it
is the correct or wrong
Old May 29, 2012 | 02:27 PM
efstunnin's Avatar
even with the car on(II) and the sending unit unplugged the needle still ddoesnt go down
90si-rex
Jul 7, 2014 02:17 PM
doubleoazn03
Mar 26, 2013 11:53 AM
hirogx
Mar 12, 2011 07:59 AM
SpEcIaLkOuPe
Apr 25, 2009 12:58 PM
Vtec92Civic
Feb 9, 2003 11:54 PM
