Difference Between an AT and MT Rad?
Old May 29, 2012 | 11:41 AM
Blacknight117's Avatar
Icon2 Difference Between an AT and MT Rad?
I`m going to be ordering my aluminum rad for my EJ1 in the next week. I have a few in mind but they say MT only. Is there a differenct between the AT and MT rads? I have an EJ1 with an auto D16Z6..
Old May 29, 2012 | 11:43 AM
Axatax's Avatar
Default Re: Difference Between an AT and MT Rad?
Yes, the AT rad. is also the transmission cooler.
Old May 29, 2012 | 11:44 AM
Dc4LsTeG's Avatar
EK9
X2 the a/t ones have fittings for the transmission lines
Old May 29, 2012 | 11:47 AM
grumblemarc's Avatar
The Grumpiest
I've never seen an aftermarket aluminum rad for an auto. Then again, I wasn't looking. You would have to run a separate cooler.
Old May 29, 2012 | 11:50 AM
FYI: This is the one I`m looking at. It says MT, so I`m not sure if it will or will not work with my ej
Old May 29, 2012 | 11:52 AM
Dc4LsTeG's Avatar
EK9
Don't think so. But id email go autoworks and see if they have one that will
Old May 29, 2012 | 11:53 AM
Ugh, I hate `havin a AT
Old May 29, 2012 | 11:57 AM
Axatax's Avatar
Swap it. Nothing to it.
Old May 29, 2012 | 12:00 PM
DCRB's Avatar
qft.
o/p you would have to run an external trans cooler with that radiator. if you're feelin cheep get one out of an old ford explorer
Old May 29, 2012 | 12:01 PM
chewyv's Avatar
pm4nudes
But why do you need a radiator that has a higher cooling efficiency? Or are you just looking for a smaller radiator to make room?
Old May 29, 2012 | 12:05 PM
The Grumpiest
I don't think they do.
That's the one I have. It won't work.
Trying to make room. I could just go the cheap route and just get a slim fan...would that make more sense?
Old May 29, 2012 | 12:09 PM
The Grumpiest
No. The shroud on the OEM fan is what makes the difference.
Old May 29, 2012 | 12:12 PM
So, I can remove the shroud than?
Old May 29, 2012 | 12:15 PM
The Grumpiest
The fan/shroud is one piece. You cannot just remove the shroud. Even if you could you would lose a lot of cooling capacity.
Old May 29, 2012 | 12:17 PM
I could get a slim fan for the OEM rad, right?
Old May 29, 2012 | 12:22 PM
The Grumpiest
You could but you will probably get the same result, reduced cooling capacity. The shroud is what makes the fan more efficient. If you do, don't throw the old fan away.
Old May 29, 2012 | 12:26 PM
chewyv's Avatar
pm4nudes
How about using an external atf cooler? You could mount it as you would an intercooler.
Old May 29, 2012 | 12:59 PM
furious94ls's Avatar
Why not just use another OEM a/t rad. What do you need to make room for? It's an auto D-series?????
Old May 29, 2012 | 01:18 PM
I want to clean up the engine bay a bit. After 17 years, it deserves to be nice looking again. And yes, I had no choice since my dad got the car in `96 off a lease.
Old May 29, 2012 | 01:20 PM
Im not knocking the fact that it's an auto. Mine is auto. It's just that there is no performance reason to do this.
If it's just for looks then you will have to do as stated above and run an external ATF cooler. Good luck
sktyrhrtout
12
Jul 16, 2009 03:37 PM
sony224422
Jun 7, 2007 12:58 PM
deeweezy187
Jan 5, 2007 03:26 PM
MansuDC2
Mar 7, 2006 06:32 PM
sleepyhamsterlx
19
Aug 20, 2003 03:24 PM
