92 EX coupe A/T-CEL & ABS light both on... already searched
I am getting a CEL and ABSL at the same time or close to coming on at the same time, but every time I shut the car off they go away and then come back on upon a minute of driving and then the cycle starts again. I tried to link the service connector, but since the light resets itself every time. idk what to do. The car runs and sounds fine as well. any ideas?...
Make sure all your fuses are installed and completing the circuit. If the memory fuse is blown it will not store the codes.
Well the CEL comes on and the ABS light as well... so there has to be codes... but as soon as I shut the car off and turn it back on the lights go out... so I cant retrieve the codes.
A code can be set and stored in the ECM memory, the CEL light does not always stay illuminated. If its a hard fault the CEL will stay on, if its intermittent then it may just store the code. Find the blue connector jump it and turn the car to on.
I did jump the service connector and nothing happens... the code keeps resetting and idkw
FurryBalls
Aug 30, 2012 06:21 PM
kit50si
Nov 21, 2007 01:24 PM
LS1powered
Apr 27, 2006 09:13 PM
