How long are obd codes stored on the ECU
codes are stored in the ECU until you physically reset the ECU by removing power to it for about 10 seconds - the Check Engine Light will go off when the key is turned off and will stay off until another problem is detected by the ECU, however, the codes remain in the ECU
