Em1 with trans issues!
Old May 27, 2012 | 02:46 PM
hondaon18's's Avatar
Default Em1 with trans issues!
Ok so i have a em1 with a b18c lsd trans s80 to be exact. Ok so when i shift it to first and hit on the gas it takes a pretty long time to move about 4500 to. 5000 rpms . Also if i let the my foot off the clutch when in first it wont shut off . I can drive also i can shift to second with out the clutch . so when on the high way and im in 4 gear and i want to down shift or even slow down just a tap on the clutch and the car slows down like it suppose to . So has any one ever had this kind of experience . At first i thought my clutch was bad and needed replacement but now i think my trans might be done.
Old May 27, 2012 | 04:07 PM
Dc4LsTeG's Avatar
EK9
Default Re: Em1 with trans issues!
I dont understand the problem??
Old May 27, 2012 | 07:43 PM
Thats the thing i dont either i have to rev real high to move when in first gear. Then today i noticed that i can take my foot off the clutch and the car dosent turn off?? So im confussed shouldnt i stalled out?
Old May 27, 2012 | 07:52 PM
First.EG's Avatar
your clutch doesn't work.
Old May 27, 2012 | 08:04 PM
Well im thinkin that but when im on the high way i can drive just fine and go threw all the gear ok .
Old May 27, 2012 | 08:31 PM
Safety_Driver's Avatar
When the car is already moving it's easy for the clutch, but when standing and want to move is the hardest task for the clutch.
Old May 27, 2012 | 08:48 PM
crawfo661's Avatar
if you can dump the clutch in first gear and not kill the engine your clutch is gone, end of story
Old May 27, 2012 | 09:39 PM
jbpnoman's Avatar
Or his clutch pedal isn't adjusted correctly, or his clutch master cylinder is shot, or his clutch slave cylinder is shot.
OP, check your clutch master cylinder reservoir, check your clutch pedal linkage, and check your clutch lines (there's only about 3 feet of line) for any leaks, kinks, or breaks.
Old May 28, 2012 | 07:09 AM
Ok i checked my fluids fine i see the hoses fine. At high speeds i can shift fine . But i do think my clutch is gone . How much does a clutch install go for?
Old May 28, 2012 | 07:12 AM
How do you adjust a clutch pepal ?. Also if my slAve cylinder was shot i think i woulndt be able to shift right. Cause i had a similar problem with my hatch and i could only shift when the car was off but the shift when the car was on
Old May 28, 2012 | 07:26 AM
jbpnoman's Avatar
On the pedal itself, at the top, there's a threaded rod with a nut. Yes, I'm over-simplifying it. You use that nut to adjust it.
Old May 28, 2012 | 07:36 AM
Oh okay but in my case i think my clutch is toast . But thanks for your help. Now what would be a good stage 2 clutch to put on . I was looking at the excedy
Old May 28, 2012 | 07:51 AM
hannslebo's Avatar
http://www.ebay.com/itm/EXEDY-DAIKIN...0aa384&vxp=mtr
This will work fine for you.
Most shops average around 300-400 to do a clutch on these cars. Save some money and DIY - Very simple job if you have a friend to help and a you are not completely mechanically challenged.
Old May 28, 2012 | 07:58 AM
Yea i was looking to do it myself . I did one before when i was younger on a crx i have the tools too . Thank everbody for the help
+1
Got the same clutch from ebay. Works great.
Change your clutch and forget about it.
My old clutch looked far from worn but with the new one is like night and day.
If your old disk looks fine (like my did) it might be the springs on the pressure plate that get old and don't hold good enough anymore.
ThaEfSwap
Nov 29, 2011 06:37 PM
86si
Feb 3, 2006 12:04 PM
lokodog
Dec 25, 2005 09:39 PM
Chief Brody
Aug 4, 2004 09:28 PM
illusion
Apr 17, 2002 08:06 PM
