Please Help 97 Prelude wont start sometimes
Old May 26, 2012 | 06:49 PM
j.roberts0790's Avatar
Default Please Help 97 Prelude wont start sometimes
Ok so my sister in-law has a 97 prelude with over 200k miles. This car has always been trouble. Will not start here and there. Sat for sometime not running would crank over and had essentials spark, gas, compression. Then replaced distributor and ignition switch. Car now starts intermittently first threw a fuel trim system too lean(bank 1) so replaced O2 sensor. ran good for a day or so. Then started the started the not starting again with a new code. MAP sensor had excessive voltage. Replaced now saying TPS issue checked live feed with 9.4% at idle. Any ideas. Is it possibly a bad ecu?
Thanks
Josh Mcholland
Jul 4, 2019 06:38 PM
sumocivic
May 12, 2013 11:10 AM
justint
May 9, 2006 03:44 AM
Preludegirl
Apr 11, 2005 01:51 PM
