please help with mystery cooling problem.
Old May 26, 2012 | 02:30 PM
95F22B2's Avatar
Default please help with mystery cooling problem.
i have an F22B2 accord LX,
on 3/1/12 i had the water pump and timing belt replaced.
about a month or so after that, i was driving one day and the temperature climed all the way up to the red. stopped and checked, the radiator was empty as was the reservoir, so i filled up both.
that lasted a few weeks, and now the problem is back and comes back about a week after i put more coolant in the radiator.
the reservoir is full, and the radiator is maybe a cup or so low on coolant.
i took the car back to my mechanic about 2 weeks ago and he pressure tested everything and check the underside for leaks, and says everything was fine, he also checked the fan relays, everything.
after it comes up to operating temperature, and i stop for a red light, it over heats all the time.
cant think of anything.
please help!!
Justin
Old May 26, 2012 | 03:34 PM
v4lu3s's Avatar
RTFM
Default Re: please help with mystery cooling problem.
has the system been well bled of air bubbles?
Old May 26, 2012 | 04:19 PM
djkurious's Avatar
This
Old May 26, 2012 | 06:15 PM
95F22B2's Avatar
My mechanic did all the work. I'm pretty sure he would have did that. I'm not really sure. If it wasn't bled properly would that cause the symptoms that I'm having?
Old May 28, 2012 | 03:35 AM
Lost Again's Avatar
Yes this can cause issues.
Are you sure the fans are coming on? I see you say "he tested" them but I would want to be sure, start the car in the driveway with the hood up (ac off), watch the temp gauge, as it gets to ~half or just above the fans should kick on....do they?
If the ac is working, when you turn it on the fans should come on as well.
When the other work was done, was the t-stat replaced?
Old May 28, 2012 | 05:36 AM
hondaOchibi7's Avatar
So your radiator gets low on coolant but your reservoir remains full? If so check and replace your radiator cap. As far as overheating at a stop this sounds like your cooling fan/s isnt coming on however check your thermostat for proper operation as well..
Old May 28, 2012 | 08:20 AM
95F22B2's Avatar
the reservior is always full always to the top, and i notice that none of it goes back to the radiator. i will replace the cap. the fans do come on, and i am going to attempt to replace the thermo.
yes, the fans do come on, and i will check again to make sure that they do. when i replaced the water pump the thermostat was not replaced, as far i know it could be original.
Old May 28, 2012 | 10:16 AM
So yea replace the cap so ur rad will drink from the reservoir like its sposed to. If ur fans are working thats good. Replace your thermostat as that can be the issue and for preventative maintenance reasons and bleed or have the system bled of air PROPERLY. Thats my advice..
Old May 28, 2012 | 01:23 PM
95F22B2's Avatar
I'm going to call Honda tomorrow about the cap, and then when I have extra time off I'll do my thermostat. And am I able to bleed my system myself, or should I take it to a mechanic?
Old May 28, 2012 | 04:09 PM
phootbag's Avatar
The hose came off the reservoir cap and is in the bottom of the reservoir. Coolant goes out, air goes in.
Old May 28, 2012 | 08:16 PM
95F22B2's Avatar
The hose is still on the cap of the tank
Old May 28, 2012 | 08:26 PM
h22swapej1's Avatar
had tat problem turned out that i had a small whole in my radiator from my radiator support it diddnt seem like it was leaking but after a month of driving and 4 bottles of antifreeze i decided to check the radiator
Old May 28, 2012 | 09:03 PM
kageshin's Avatar
no, that problem will be discover when the mechanic pressure tested the cooling system....as the pressure will force the coolant to leak out from the hole/crack/etc.
Old May 29, 2012 | 10:04 AM
95F22B2's Avatar
Called Honda for prices on the rad cap. And the guy said that there are 2 different ones available and that there were 2 different rads that were put in. How do I know which on I have. I've looked everywhere for the brand.
Old May 29, 2012 | 02:19 PM
v4lu3s's Avatar
RTFM
i would take the cap off and get one like it at a parts store. odds are you have not had an oem honda radiator for years as most people replace em when they die with much cheaper aftermarket ones.
Old May 29, 2012 | 03:34 PM
This.
Old May 29, 2012 | 06:23 PM
95F22B2's Avatar
Agreed. I'll pop by and get one friday
Old Jun 5, 2012 | 03:10 PM
95F22B2's Avatar
installed new thermostat with gasket. when i went to install it, i saw that there wasnt a thermo in there, no wonder i was having problems...
Old Jun 5, 2012 | 03:30 PM
Hidenplanvew's Avatar
Actually aftermarket rad caps suck, I would get an OEM.. Your not having a thermostat dosent make coolant empty out of the rad... possible bad head gasket?
Old Jun 5, 2012 | 05:18 PM
v4lu3s's Avatar
RTFM
oem doesnt always fit an aftermarket radiator...
Old Jun 5, 2012 | 06:14 PM
nus_dogg's Avatar
x2!
Old Jun 5, 2012 | 08:19 PM
OhShietTommy's Avatar
Im not sure if this is the same thing that happened to my accord but it almost had the same problem with the temp gauge going all the way up. For my accord at least, the temperature of the engine would rise up to a certain temp and thats when my radiator would start up and replace the hot fluid with the cooled down fluid and by fluid i mean coolant if that makes any sense lol. As long as the car doesn't start smoking and such it should be all good
Old Jun 6, 2012 | 05:24 AM
Updates 95F22B2??
Old Jun 6, 2012 | 06:14 PM
95F22B2's Avatar
Updates 95F22B2??
installed a new thermostat, there wasn't one when i opened up the housing, and i put in new coolant and bled the system.
going to drive the next few days to see how it is.
Old Jun 6, 2012 | 06:25 PM
95F22B2's Avatar
double post
jasb750
Jul 7, 2013 06:05 PM
J1A1H
18
Jan 8, 2006 12:13 PM
bigslimdog
Aug 10, 2004 03:37 PM
tonezilla
Mar 22, 2004 07:35 PM
Specialk
May 22, 2003 08:59 AM
