PA PHILLY 93 HONDA DEL SOL LSVTEC TURBO LSD GSR TRANS SALE OR TRADE
I HAVE A 1993 HONDA DEL SOL SI LS/VTEC TURBO WITH FRESH REBUILT GSR TRANS FOR SALE. CAR IS INSURED AND REGISTERED WITH CLEAR TITLE. PA INSPECTION CURRENT. NO TEST DRIVE UNLESS CASH IN HAND. TRADES- 4500 VALUE LET ME KNOW WHAT YOU GOT. CASH ON TOP DEPENDING ON VALUE OF TRADE. I WANT 4000 FIRM. CASH IN PERSON. NO SCAMS. NO SHIPPING. NO CHECKS. LOCAL DEALS.
1993 DEL SOL SI- 171K MILES- CAR WAS RED, I HAD EXTERIOR PAINTED BLACK. PAINT JOB NOT PERFECT. BUT CAR STILL LOOKS DECENT. DOOR JAMS, UNDER HOOD, AND UNDER TRUNK STILL RED. COULD USE A DETAIL- SAND AND BUFF
ENGINE
B16 HEAD- APPROX 60K MILES. AEM CAM GEARS. PORT AND POLISHED.
B18 BLOCK- APPROX 300MILES SINCE BUILT
BLOCK WAS CLEANED, HONED, CHECKED
CRANKSHAFT WAS CHECKED AND CLEANED
81MM STOCK BORE CP FORGED PISTONS 9:1 COMPRESSION
SCAT FORGED RODS WITH ARP ROD BOLTS
ACL BEARINGS
ARP HEAD BOLTS
NEW WATER PUMP, BELTS, SPARK PLUGS, GASKETS, SEALS.
OIL PUMP FROM B16- APPROX 60K MILES
COMPRESSION WAS CHECKED- GOOD- 175 IN EACH CYLINDER
RESURFACED FLYWHEEL
LS/VTEC KIT WITH SANDWICH PLATE
TRANSMISSION
USDM GSR TRANS WITH LEGIT VIN TAG ATTACHED.
NEW COMPETITION STAGE 4 CLUTCH- 6 PUCK
HONDA MTF FLUID.
TURBO KIT
TURBONETICS TURBO T04E OR T04B- REBUILT WITH NEW SEALS. CAPABLE MAKING 350HP
BLITZ SUPER SOUND BOV
TIAL WASTEGATE 7PSI
INTERCOOLER
DRAG MANIFOLD
PIPING, HOSES, CLAMPS
GM 3 BAR MAP SENSOR
BOOST PSI GAUGE
OIL PSI GAUGE
A/F RATIO GAUGE
RC550 INJECTORS
SCREEN FILTER FOR TURBO
TURBO CONTROLLER- WAS DISCONNECTED
P28- CHIPPED NEPTUNE
DYNO TUNED BY HANNA AT ROOTS FACTORY IN 2009
ON 7PSI- 208 WHP AND 152 WHEEL TORQUE. IT COULD BE FASTER IF RETUNE WITH NEW WASTEGATE SPRING OR TURBO CONTROLLER.
2.5-3IN?? EXHAUST OBX
NEW B SERIES SHIFT LINKAGE FROM HONDA
NEW RUBBER ROOF SEAL FROM HONDA
TINTED REAR TAIL LIGHTS
1 PIECE HEADLIGHTS
EBAY HID KIT
EBAY DUAL CORE RADIATOR
EBAY SLIM FAN
SKYTEK PAGER ALARM WITH KILL SWITCH
WALBRO FUEL PUMP
FUEL FILTER GAUGE
SONY RADIO- WORKS BUT DISPLAY NOT SHOWING UP.
NEW DRAG RIMS DR16 WITH NEO GEN TIRES- APPROX 300 MILES
NEW BRAKES AND ROTORS
THE BAD-
SLIGHT OIL PAN LEAK
THE FRONT RADIATOR SUPPORT IS A LITTLE BENT. I ADJUSTED BUMPER TO LOOK DECENT.
DRIVER SEAT HAS HOLE BUT STILL USEABLE
Pics can be seen at my ebay ad
http://cgi.ebay.com/ebaymotors/93-HO...item4166d381ee
ENGINE
ACL BEARINGS
ARP HEAD BOLTS
RESURFACED FLYWHEEL
TRANSMISSION
HONDA MTF FLUID.
TURBO KIT
TIAL WASTEGATE 7PSI
INTERCOOLER
DRAG MANIFOLD
GM 3 BAR MAP SENSOR
BOOST PSI GAUGE
OIL PSI GAUGE
A/F RATIO GAUGE
RC550 INJECTORS
1 PIECE HEADLIGHTS
EBAY HID KIT
EBAY SLIM FAN
WALBRO FUEL PUMP
FUEL FILTER GAUGE
THE BAD-
SLIGHT OIL PAN LEAK
How can I email for pics when there is no email address? Go on www.imageshack.us to post pics
jerryx1010@hotmail.com
i can email you pics.
jerrx1010
Jun 2, 2012 05:35 AM
jerrx1010
Sep 22, 2011 05:17 AM
jerrx1010
Sep 22, 2011 05:13 AM
