replacing knock sensor on a b16
Old May 25, 2012 | 07:05 PM
gokus-eg2's Avatar
Default replacing knock sensor on a b16
I was trying to rewire my o2 sensor connector and pulled on the harness to hard to reach the wires and broke the plastic off the knock sensor on my b16. .. it started giving me the code so i just popped it back in and the light went away. ... i already bought a new, my question is. ..is there a way to remove it with out having to take off the whole manifold or is that a must???? Anyone have any crazy simpler ways of doing it???? thanks in advance.
Old May 25, 2012 | 11:51 PM
Dc4LsTeG's Avatar
EK9
Default Re: replacing knock sensor on a b16
Its possible, you need a socket that will fit and you need to lay under the car as if you were changing the oil filter. You might have to remove the oil filter and unlug the couple plugs around there and get the wires out of the way
Old May 26, 2012 | 02:23 AM
HondaPartsHero's Avatar
Technical Hero
It's a 27mm deep socket btw
Old May 26, 2012 | 05:17 AM
ifIexplode's Avatar
Yep, Id get the car off the ground on jack stands or a lift if possible. Get the socket and ratchet on the knock sensor with an extension and you should be able to get it off from underneath, Do it when the car is warm too. NOT HOT.
Old May 26, 2012 | 11:26 AM
gokus-eg2's Avatar
NICE!i was just eyeballing it and it lookd like i need to take the whole mani off, def did not wanna do that thanks alot everyone
Old May 26, 2012 | 12:08 PM
chewyv's Avatar
pm4nudes
I use an open end wrench. I wasn't able to use a socket with the manifold still attached.
Old May 26, 2012 | 04:00 PM
gokus-eg2's Avatar
yea i just tried the socket and it wouldn't fit, i thought it was cause of my skunk 2 manifold but i guess its like that with others too, ill try the open wrench, thanks
normc
Aug 11, 2009 05:11 AM
hoezee
Oct 6, 2008 10:40 AM
bb4socal
Feb 25, 2006 03:46 PM
wullie_vtec
Feb 3, 2006 02:33 PM
smash fascism
Nov 6, 2004 10:09 AM
