AR15 trade for B series swap (legal deal)
I have a custom built 16" AR in .223 has magpul stock and a quad rail very little ammo threw her was my back up AR
looking to swap for a B18-B20 swap 5 speed VTec or not just no auto's
possably throw in a few $$ if its a special deal or turbo or built low compression whatever hit me up!!!!
located in chatsworth CA 91311:scared
gun has to be transfered at a gun shop I will pay the fees
Dan looking for a ar!!! But rather have the 5.56 do to the fact it can shoot the 223 not the other way aroun bump!!!!! Hit me up if your willing to trade for a b20v turbo built short block.
Ok just making sure because you said .223. Took it as only a set caliber du to the fact 5.56 is a hotter round. Yea the b20 I have is a short block built for turbo great motor but you still need a head and a tranny ect the short block alone is worth 1100 easily
9:1 cp pistons acl berrings golden egale rods balanced 84.5 mm bore stock sleeve has block guard type r water oil pump timing belt. Has been broken in made 357 hp at erikcs racing on a s100 with a b16 head and ctr cams at 7psi
