LS rods on gsr crank?
Old May 24, 2012 | 06:19 PM
carlossolorzano's Avatar
Default LS rods on gsr crank?
So i have a question will LS rods fit gsr crank or b16 crank?
Old May 24, 2012 | 06:22 PM
doood's Avatar
been there done that
Default Re: LS rods on gsr crank?
not as simple as bolting them on
Old May 24, 2012 | 06:31 PM
wat would i have to do???
Old May 24, 2012 | 06:37 PM
dlo253's Avatar
Take some measurements and find out..
Old May 24, 2012 | 07:12 PM
cagedGSR's Avatar
i thought ls rods on a gsr crank would hit the head? or am i thinking gsr rods on ls crank? I can't remember.
Old May 24, 2012 | 07:14 PM
Hidenplanvew's Avatar
use a ls crank..
Old May 25, 2012 | 10:18 AM
oh i see... im goin turbo
Old May 25, 2012 | 10:19 AM
Dc4LsTeG's Avatar
EK9
Old May 25, 2012 | 10:37 AM
TunerN00b's Avatar
So, for a turbo, you want to put the longer rods on the shorter stroke crank...
Old May 25, 2012 | 01:53 PM
snailspins's Avatar
do you have a GSR block or a LS block? and why do you want to know? If you have a LS block and are trying to increase the compression slightly you can use GSR pistons on LS rods and crank but they have to be machined to fit.
Old May 25, 2012 | 08:00 PM
i have a ls block b18b1, i spun the 3rd cylinder rod bearing,i have ls eagle rods,im going to buy cp low compression piston,micro polish crank and bore out block 81.5mm
Old May 25, 2012 | 08:14 PM
Dc4LsTeG's Avatar
EK9
Ok just make sure you keep matching crank/rods
Old May 25, 2012 | 08:17 PM
wat u mean ? im keeping my ls crank wit my ls eagle rods...wat kind of rod bearings should i get
Old May 25, 2012 | 08:21 PM
Dc4LsTeG's Avatar
EK9
ls bearings.. I mean just what I said keep matching crank/rods, as you are doing.
Old May 25, 2012 | 10:28 PM
Solster's Avatar
1. the bearing on the LS rods is wider then the GS-R rods.
2. the GS-R uses a oil Sprayer system to spray oil on the bottom of the Piston this lubes the wrist pin cyl walls and cools the piston down. where the LS has a Hole in the Rod Bearing and a Hole in the rod then squirts oil on the cyl wall and relighs on the oil ring to collect oil from the cyl wall to drip on the wrist pin.
and the GS-R (b18c1) crank has a 87.20 mm stroke and the B18A/B crank is 89.00 mm so just a crank swap would drop the compression ratio from 9.6:1 CR with a piston to deck hight of 0.013 to 8.75:1 CR with a Piston to deck hight of 0.049
So if the rods where not as wide as there are you could do it. but i would just get dished piston and keep the LS rods
Old May 25, 2012 | 11:04 PM
my eagle rods i have for LS dont have the hole on the rod for the oil? y is that?
Old May 25, 2012 | 11:09 PM
Dc4LsTeG's Avatar
EK9
because neither do oem
Old May 25, 2012 | 11:11 PM
my oem rods i have do have it...
Old May 25, 2012 | 11:13 PM
Dc4LsTeG's Avatar
EK9
which hole are you talking about? I thought you meant why is there a hole in the bearing and no hole on the rod
Old May 25, 2012 | 11:21 PM
yea thats wat im talking about... my oem rods have a lil hole slight to the side,,,and my eagle rods dont have any holes
Old May 27, 2012 | 01:12 AM
Solster's Avatar
Odd almost sounds like GS-R rods
turbohatch eg6
Jul 23, 2009 06:04 PM
bigbadboy
Aug 28, 2006 06:20 PM
jdmsijdm
Dec 19, 2004 10:53 AM
electric_rex
Dec 5, 2004 02:57 PM
