Another "Accord won't start" thread
I am stumped! I've search for issues and can't figure it out.
Symptoms are simply that the car wont start. Turn the key and all I get is a "click" under the dash.
I automatically go to the cheapest, easiest accessible solution and check all fuses.
First expensive mistake was replacing an apparently perfectly good starter as that was not the problem...
Next thing I see people talking about is the main relay. After busting a few knuckles I got to the relay and pulled it down. I inspected the board for weak/bad solder points and none look suspect...
I found that I do have fuel, though I wouldn't suspect that to be the problem anyway since the car won't even crank.
Please help me get my work car back on the road!
EGk3nrock
15
Aug 29, 2007 01:00 PM
SpdFrk
15
Jan 14, 2005 05:13 PM
