02 honda accord coupe -car shuts-off random
Old May 23, 2012 | 12:10 PM
jose6382's Avatar
Default 02 honda accord coupe -car shuts-off random
my car shuts- off while I'm driving. the dash board light come on and i have to put it in neutral or parking to restart the car. some times it restarts right away .some times i have to wait a couple of minutes before it restarts. Had the idle valve changed,distributor changed. But the problem does not go away. Can anyone help me out . Tired of wasting money.
Old May 23, 2012 | 02:24 PM
holmesnmanny's Avatar
Default Re: 02 honda accord coupe -car shuts-off random
sounds like main relay problem
Old May 26, 2012 | 08:51 AM
moparbob498's Avatar
could also be ign. switch also. was a recall on this issue. its worth checking into. good luck
Old May 26, 2012 | 10:40 AM
Silver6gen's Avatar
Sounds like my problem, see this thread
https://honda-tech.com/forums/honda-accord-1990-2002-2/cg6-f23a4-stalls-when-hot-3059224/
I replaced the relay that controlls the fuel injectors and it helped a bit but it still happens, is it the Ignition control module or the ignition switch? It only happens when it is really hot
Old May 26, 2012 | 10:45 AM
Silver6gen's Avatar
I found this thread that might save you a couple hundo if it is the ignition switch.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1998-2002-honda-accord-ignition-switch-replacement-2353017/
I think this might be my next check.
Mark Hurd
Apr 27, 2015 03:10 AM
kennymcd
Oct 13, 2014 01:56 PM
pacdecimal
Jul 7, 2014 07:16 PM
brandonw91
Apr 20, 2014 10:48 PM
Elvis1977
Jun 19, 2007 06:35 AM
