Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Accord (1990 - 2002) (https://honda-tech.com/forums/honda-accord-1990-2002-2/)
-   -   02 honda accord coupe -car shuts-off random (https://honda-tech.com/forums/honda-accord-1990-2002-2/02-honda-accord-coupe-car-shuts-off-random-3058575/)
jose6382 05-23-2012 12:10 PM
my car shuts- off while I'm driving. the dash board light come on and i have to put it in neutral or parking to restart the car. some times it restarts right away .some times i have to wait a couple of minutes before it restarts. Had the idle valve changed,distributor changed. But the problem does not go away. Can anyone help me out . Tired of wasting money.
holmesnmanny 05-23-2012 02:24 PM
Re: 02 honda accord coupe -car shuts-off random
sounds like main relay problem
moparbob498 05-26-2012 08:51 AM
could also be ign. switch also. was a recall on this issue. its worth checking into. good luck
Silver6gen 05-26-2012 10:40 AM
Sounds like my problem, see this thread
https://honda-tech.com/forums/honda-accord-1990-2002-2/cg6-f23a4-stalls-when-hot-3059224/
I replaced the relay that controlls the fuel injectors and it helped a bit but it still happens, is it the Ignition control module or the ignition switch? It only happens when it is really hot
Silver6gen 05-26-2012 10:45 AM
I found this thread that might save you a couple hundo if it is the ignition switch.
https://honda-tech.com/forums/honda-accord-1990-2002-2/1998-2002-honda-accord-ignition-switch-replacement-2353017/
I think this might be my next check.
