Hardrace VS OEM Mounts
So I shop around for a set of stiffer motor mounts that would not make the car vibrate like crazy like the silicon mounts do and that most company sell. I wanted something stiffer and better then OEM that can be used at the track and for daily driving…. I settle for a set of HardRace mounts. There quality are out standing there rubber is much better then OEM and share the same style as OEM so vibration is very low. I only notice a little of vibration when the car is cold and at idle. I did get a chance to try them out at Etown road course and boy they made a differences. when the engine shifted from acceleration to deceleration you didn’t hear any clunk noise or actually felt the weight transfer like you do with the OEM worn out mounts. So at the end I was happy ! good for daily/track use. : ) in my opinion
Underneath side mounts
transmission mount
driver side engine mount
transmission mount
If you look closely though, you will notice the Hardrace mount has the center is connected with rubber in a 3rd spot while the ITR one is not. Perhaps that helps compensate.
05foresterxt
12
Mar 1, 2011 11:57 AM
