Honda civic EF Vtec Solenoid problem!!! help!!!
Old May 23, 2012 | 11:13 AM
Brian da domi's Avatar
Icon2 Honda civic EF Vtec Solenoid problem!!! help!!!
Ok i have this honda civic ef 1991 with vtec but the problem is that i don't know if the vtec is kicking in and i already bought a new vtec solenoid install it and everything. Does anybody know what could break from the vtec solenoid if its the plugs or the pressure sensor? or maybe the top of the vtec solenoid? If you had the same problem or if you know about these things please let me know or comment on this post, thank you!
Old May 23, 2012 | 11:37 AM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: Honda civic EF Vtec Solenoid problem!!! help!!!
I know about those VTEC solenoids.
What makes you think VTEC is not working?
Do you have a CEL?
PS:
Try not to make the letters bigger, it's annoying.
Old May 23, 2012 | 12:01 PM
that i know the guy i bought it from he told me that it doesnt kick in the vtec when im going 100mph like if i keep going a little bit more it starts to stop. i dont know if it does that because of the vtec or because the computer is locked. though, the car takes off fast it has a b18 vtec but after 1st gear it runs slow or on 3rd gear and the rpm goes fast up
Old May 23, 2012 | 12:36 PM
ochata's Avatar
Do you have a CEL?
PS:
Old May 25, 2012 | 10:32 PM
no i dont have a cel only when i unplug the plug from the pressure sensor.
Old May 25, 2012 | 11:02 PM
DCRB's Avatar
dude. why don't you post up specs of your motor, whats done to the car etc. I can't see your car, therefore I cannot diagnose what's wrong over the internet. you could have anything from a mini me to a j35, and an obd0 ecu to stand alone. need more info
DCRB's Avatar
Old May 29, 2012 | 03:54 PM
sir-tecalot's Avatar
Run a wire from your positive connector on your battery and touch the top of the solenoid with the other side and listen for it popping open if it pops its working fine! then check the filter in the solenoid for gunk and crap sometimes that bogs vtec down!
Old May 31, 2012 | 10:46 AM
alright im going to take several pictures and i have a p28 ecu i also changed the vtec solenoid. im sorry i dont know what a spec of motor is but im going to take a pic of my engine. and thanks guys!!
Old May 31, 2012 | 10:47 AM
yea imma take pics but i dont know what is a spec???
Old May 31, 2012 | 10:48 AM
thanks ill do that and im going to take a pic with the solenoid off and everything!
Old May 31, 2012 | 11:03 AM
91EFH22's Avatar
Well I know that the ecu should have a speed limiter, so your 100mph runs will only make it to about 110-115. Its not Vtec.
As for your description, check the oil level, timing, vtec sel....
Old Jun 3, 2012 | 05:25 PM
"when im going 100mph like if i keep going a little bit more it starts to stop".... this sounds like a speed limiter as 91efh22 says.... "after 1st gear it runs slow or on 3rd gear and the rpm goes fast up" Im stomped on this one sounds like a dodgy conversion or probably loose wire on vss or somewhere?? dizzy probs?? what b18? b,c,c4,c5 ect for obd1 is it a jumper or made loom?
nosw22
Honda Civic (2001 - 2005)
Aug 26, 2012 10:29 AM
willem
16
Feb 19, 2012 04:07 AM
camp_kill_yourself
Jul 15, 2006 06:26 PM
353hpprelude
Jul 14, 2005 07:48 PM
giz
Jun 30, 2003 12:31 PM
