rust on my R
Old May 23, 2012 | 10:49 AM
honshu's Avatar
Default rust on my R
All I can say is, WTF!!!! Bought the car and didn't check it, which is my fault. The car is mine now so I want to get rid of it. What are you guys doing to rid the crust?
Old May 23, 2012 | 11:06 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Re: rust on my R
not much you can do man depending on how bad it is...you can either replace the panels that are rusitng or if it's just surface rust you can take it to a body shop and have them take a look, or if you do body work yourself make it a project..gl
Old May 23, 2012 | 11:19 AM
John M's Avatar
Pics of rust?
Old May 23, 2012 | 12:00 PM
sykoenigma's Avatar
i had rust on my dc5 and had a body shop cut out the rust and weld in new sheet metal..
Old May 23, 2012 | 12:16 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
aaaaaaaannnnnnd thats what happens when your so headoverheels about the car and cant wait to get it home and dont do a full inspection...lol.... it happens...
gl
Old May 23, 2012 | 11:19 PM
2000FBPITR's Avatar
PICS of the rust would help find the best remedy.
Old May 24, 2012 | 06:35 AM
honshu's Avatar
Will post them tonight. It is not bad, all of it is surface rust and most of it is on removable parts. The body is in good condition, have a few dings from doors and some scratches.
Old May 24, 2012 | 01:27 PM
R boy fresh's Avatar
Your best bet is to have it professionally cut out and replace the metal..
Old May 24, 2012 | 02:25 PM
ekcoupeh22's Avatar
^x2 everything is fixable
Old May 24, 2012 | 08:18 PM
j13's Avatar
j13
Post pics
Old May 25, 2012 | 04:02 AM
etank82's Avatar
Sounds like he's referring to undercarriage rust as opposed to body rust. The latter would have most likely been apparent to the naked eye without close inspection, whereas the former could go undetected in haste.
Old May 26, 2012 | 06:31 AM
honshu's Avatar
Etank82, you hit the nail on the head. The body is great, there is no rust at all, it wasn't until I put the car up on a lift that I saw the crust on bottom side. Photos are coming in a few minutes. Thank god I don't have to cut panels and replace, that would suck.
Old May 26, 2012 | 07:09 AM
honshu's Avatar
The guy added undercoat :-/
This was before the wash, which should have knocked the spiderwebs off the car. He had a garage and said he didn't drive the car for two years, it is reading in at 54K on the odometer.
Old May 26, 2012 | 07:24 AM
ekcoupeh22's Avatar
your worried about suspension rust???? thats real easy to fix!!! my R sat outside for 10 years and it had the same amount as that
Old May 26, 2012 | 10:32 AM
CRX Si69's Avatar
you seriously want to get rid of the car because of suspension parts rusting?
at first i thought u had bad body panel rust, the rust you have is nothing..
Old May 26, 2012 | 10:59 AM
Just simply replace whats u think is badly rusted , sand and properly coat the rest... If your still not satisfied por15 the undercarrage as well and call it a day.
Old May 26, 2012 | 10:04 PM
Tooburns's Avatar
nothing to go crazy there, i was excpecting something 1000000% worst then that
Old May 26, 2012 | 11:04 PM
j13's Avatar
j13
Looks like you're missing the flywheel cover. Better check the vins on that puppy.
Old May 27, 2012 | 09:17 AM
ekcoupeh22's Avatar
I have a type r flywheel cover if you want to buy
Old May 27, 2012 | 08:27 PM
honshu's Avatar
Yeah, after I got heR cleaned up it looked a whole lot better. The rust is all on parts, got a little work to do to knock the cobwebs off. Sure glad she doesn't look like that crusty car in the snow, that would suck *****.
Why do I need to check VINS for a missing cover?
Thanks Bro. Will have my hands full with this one, being from Cleveland I hate the sight of anything that looks like rust. By the way, you may want to change your name to R MAN FRESH with that epic build you have going. Big ups to you on building one of the best rides on the road!
Old May 30, 2012 | 03:04 PM
dragged's Avatar
Why would you take it off for no reason? Just to check and see if the numbers are matching.
Old Jun 1, 2012 | 09:47 PM
honshu's Avatar
Ok, I see there is a VIN number on the casing, did not know this.
Old Jun 1, 2012 | 09:49 PM
honshu's Avatar
I look at the engine, the plate for the B18C5 is red and there is no VIN on the block, the transmission has the VIN from the car. The guy said the block was replaced due to the engine being blown.
Old Jun 2, 2012 | 01:05 AM
OmarR's Avatar
no es bueno.
Old Jun 3, 2012 | 11:10 AM
honshu's Avatar
i got the receipt for the block replacement from Rosenthal Acura, over $8k total. I am good with it. So far this guy has been honest with me about the details with the car.
