93 GS-R
Old May 23, 2012 | 12:11 AM
KILLAB17VTEC's Avatar
Genetically Gay
Default 93 GS-R
hey,my gs-r was throwin code 7.it was a throttle angle.i just replace it.took it for a ride my cel light is still on??recheck the code it was still code 7??
Old May 23, 2012 | 12:23 AM
Solster's Avatar
Default Re: 93 GS-R
Check the Wires for Shorts
Old May 23, 2012 | 01:24 AM
Genetically Gay
Default Re: 93 GS-R
what wires?i try disconnect the batt n ecu for atleast 6min still the same.
Old May 23, 2012 | 07:41 AM
mouab18c1's Avatar
Default Re: 93 GS-R
The heck is a throttle angle? You mean a Throttle Position sensor? Did you even calibrate it to .5v closed and 4.5v @WOT?
You can't just slap on a new one and expect it to be heaven.
Old May 24, 2012 | 06:56 AM
Solster's Avatar
Default Re: 93 GS-R
Throttle angle is the term for the location of the throttle plate in the throttle body.
a bad TPS or if someone uses the Throttle plate stop screw instead of the Idle air screw to set idle will set this code.
The wires to the TPS are the ones i'm talking about. you will also need to prob them to set the TPS when installing a New one.
Jeeptech
May 19, 2017 08:12 PM
Andrew Ryan P
Mar 20, 2017 07:48 PM
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
SkyliteCustomz
Honda Civic (2001 - 2005)
Nov 12, 2007 01:59 PM
D1ANCER
Mar 27, 2002 06:06 PM
