-3 AN bradied line for brakes
Old May 22, 2012 | 06:15 PM
danedoremus's Avatar
Default -3 AN bradied line for brakes
I wanted to see if anyone else has ever done -3 AN braided line for there brake setup.
I think the brake pedal would be soft with this much line in the system but wilwood makes 2 PSI Residual Pressure Valve to help with that.also i was thinking going bigger in M.C.--so that being said how is your pedal after using this kinda hose?
or if anyone has a link to a website of -3AN Stainless Steel PTFE Teflon Coated hose i would like to look in to that also.
If you have pics of your setup please post
Thanks
Old May 22, 2012 | 07:41 PM
racebum's Avatar
Default Re: -3 AN bradied line for brakes
what's russel using? i thought 3an was the standard brake line size
Old May 23, 2012 | 01:42 AM
-3 is standard brake line size,im waiting to do my hole car in in this but im thinking there will be to much flex in the hose there for the brake pedal will be soft a little bit.
Old May 23, 2012 | 04:39 AM
EsotericImage's Avatar
Retired Moderator
i wouldnt do the whole car in -3.. just the normal SS brake lines at each wheel.
daboy155
Suspension & Brakes
Sep 18, 2017 06:59 PM
justinball1717
Honda Civic (2001 - 2005)
Oct 24, 2016 06:43 PM
5spdfrk
Suspension & Brakes
Oct 1, 2009 08:56 AM
