DC5 R susp on civic EM2! Difficult to do?
Hello Everyone!
I bot a susp (dc5r) for my honda civic (EM2) '01 it's brembo brakes, I see that i need to change stabilizer bar (front/rear), struts (front/rear). I have master/buster, prop valve from RSX (base) should i change this for Type R master/buster or I leave it like this? Are the e-brakes longer than usual e-brakes of EM2? So i would need to find e-brakes too.
thank u
PS: my hubs changed from RSX (base).
thank u
I bot a susp (dc5r) for my honda civic (EM2) '01 it's brembo brakes, I can see that i need to change stabilizer bar (front/rear), struts (front/rear). I have master/buster, prop valve from RSX (base) should i change this for Type R master/buster or I leave it like this? Are the e-brakes longer than usual e-brakes of EM2? So i would need to find e-brakes too.
thank u
thank u
Also what year of EM2 do you have? 01-03 you are going to need to change out the control arms to the DC5
04-05 should bolt up perfectly fine.
You don't need to change out the prop valve. Brake master cyclinder is bigger on the DC5 so it will improve pressure
Ebrake cable you need to get from EP3 OR DC5 OR RSX.
Also if you get the suspension from the DC5r you are going to need to get the dc5 or RSX steering tie rods
this may help you.
https://honda-tech.com/forums/honda-civic-2001-2005-78/5-lug-brake-swap-information-em2-es1-01-05-a-2662488/
Civic is 2001(LX, D17..). I have DC5R control arms sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs181.snc4/37411_803131736082_68135563_43301253_3506824_n.jpg I think RSX(base) stabilizer bar will not fit, because its smaller than DC5R. That's why I don't know what to do now with that two (front/rear) stabilizer bars.(in civic '01 there's no rear stabilizer bar I will need "progress" I think) Your post is very good , its for the RSX (base) conversion. And RSX (base) knuckles are smaller that DC5 R. I've changed the hubs, I took RSX(base) hubs and put it in DC5R knuckles.
that conversion I bought: images04.olx.ca/ui/11/05/02/1295483960_159280302_1-Pictures-of--JDM-HONDA-ACURA-RSX-DC5-BREMBO-CONVERSION-INTEGRA-TYPE-R-FOR-SALE.jpg
the same parts I have now.
I read your thread. (questions about DC5 R Brembo conversion)
I am currently running BASE RSX hubs with RSX type S calipers on D series alxes d17 motor.
for Brembo DC5R front caliper you just need the caliper brackets. for the strut bars you will need the civic ones. the RSX or DC5 will not fit. sway bars will fit over
thank u!
now my e-brakes: civic e-brakes - not fit, type R - not fit, EP3 - will try
PS: i got DC5 R struts and springs
I found that for I need change my sway bars and cross-member too, because front sway bar need another brackets.
I am telling you, in order to complete the conversion, you'll need the LONGER dc5r axles which are not compatible with you're non-k drive train. There is nothing else to say. Sorry if you've already invested money in this but you'll to to switch to K series.
I have type r full conver now!
I think to do rear disc brakes only . Rear LCA all ready on the car, master/buster, need change rear brake lines and put the RSX (base) front susp. How do u think this doable for the alignement after?
Do u have pics of your struts?
I'm lookin for civic '01 hatchback axles, for changing CV boot, I want use same side, only right side, because intermediete shaft is more expensive.
EJ8chu
Suspension & Brakes
Jan 29, 2009 05:48 AM
