92 Accord no pump no start
Old May 20, 2012 | 08:20 PM
James Olmstead's Avatar
Default 92 Accord no pump no start
KK so 1992 honda accord died after a hot start(stop at gas stop) probably 30 seconds after pulling out
20 minutes later it ran for about another 30 seconds, died while I was trying to turn around and get home(hasn't started since)
Engine turns but doesn't start
Fuel pump doesn't click on and I don't get spark at the plugs, i've tested the main relay to the best of my ability, the final step failed(fuel pump portion of the relay) but my assumption is that the relay is likely fine since we're not getting spark as well
Tommorrow i'm hoping to check the ignition switch, and to check voltage at the tps since it would indicate the computer wasn't starting up(which eliminates fuel pump from the equasion) and narrow it down, also gonna check some ground wires from the trans and another location I can't think of which apparently would prevent the car from starting
Haven't bothered to test the igniter as we didn't think it was it as it wouldn't stop the fuel pump from working(theoretically)
So anyone else have any ideas?
Old May 21, 2012 | 07:26 PM
Default Re: 92 Accord no pump no start
kk so got codes out of the computer, i believe they were 1,2,3,7,14
Anywho as I remember at the time a couple are oxygen sensors, ones the tps, ones tdc sensor and 14 is ecm/something else
I did get at my ecm and it appears to be fine, now that i'm looking around signs kinda point to the tcu(box beside it) but i never opened that one up(lol)
Another thing we're looking at now is the ignitor/icm, i'm just curious if the fuel pump could be related to the icm since the icm seems to provide some manner of power/signal to the ecm(which feeds the main relay)
Dunno, i'm tired going for a nap, maybe someone will chime in with some help as to what might possibly prevent the ecm from starting up(presumably the cause of the sensor error codes-not getting power)
Lemme know if i'm way off base or missing something(side note rotor was pretty grimey, must replace)
dman67
Jan 19, 2015 03:02 PM
Tatooine
Jun 27, 2010 07:00 PM
ej84dr
Jun 16, 2010 05:20 AM
jarymane81
Feb 10, 2009 02:35 PM
raylightt
Sep 7, 2008 08:14 PM
