putting 3rd/4th GSR gears and LSD into an LS tranny.
Smarter than you
Has anyone done this? Can u install GSR gears onto an LS tranny? I want to swap in GSR 3rd/4th since 1/2 are already the same.
Im rebuilding my LS tranny and thinking of converting it to a GSR using a B16 FD(same as GSR, 4.40) or just having GSR gearing w/ LS FD(4.26)
I am about to buy a quaffe and I was under the impression that an LS quaffe can be used w/ a b16a FD as well. so i cant go wrong getting the quaffe for an LS even if i decide to go w/ the 4.40 FD.
also, what about putting a B16 or LS Final drive into a stock GSR tranny, is that possible?
[Modified by DIRep972, 4:27 AM 10/14/2002]
1/2 synchros are the same cant split up
3/4 same thing
5/r same thing
not so sure about the final drive but i think most likely
so you on the right track. and definitely you should be able to swap out. ill ask my mechanic if you really want to know though.
3/4 same thing
5/r same thing
THe Ring Gear on a B16\LS are different then a ITR\GSR Trans.
Therefore, you can get the 4.40FD 93-97 Del Sol ring gear and use it with that B16a\LS Quaife.
Suprdave
Suprdave
