Obd0 wiring help
I am tryin to drop this b series in my ef without goin obd1 how would I wire up tha map sensor on tha throttle body since mine is on tha firewall any advice would be greatly appreciated
good luck with your o2 sensors. do you have the proper exhaust manifold or are you connecting the two wires together?
i was going to do this but after reading up on it obd1 is the way to go for sure.
You can probably get away with using a chipped PS9 running B16 maps (I can probably email you a basemap). You would only need to run 1 wire for VTEC from pin A8 to the solenoid. Also, you would still need to tune a bit, but still better than the hassle and expense of going OBD-1.
The second O2 sensor is only needed with PR3/PW0 ECUs, which are a pain in the *** to use.
