help! b18c5 stroked has a little blow by
Old May 18, 2012 | 10:18 PM
murphylee's Avatar
Default help! b18c5 stroked has a little blow by
whats done to engine
-resleeved and bored to 84mm
-crower stroker kit
-8:1 comp
-replaced pcv canister with catch can
-deleted oil squirters
-head all done up with old school jun intake mani punched out
-still no tune running on a chipped p28,but will be after i fix this problem with hondata s3
so i just found out that white smoke is comming out the breather after warm up. I never had this problem when the motor was n/a. I recently equiped the motor with an old school greddy 18g complete kit running manufactors psi. upon start up and warming up the motor thats when i saw smoke. I checked comp did wet and dry all cylinders were high in the 210 range with comp bleeding to a steady -2 to -3 psi across all cylinders and holding psi after. I cant figure out why smoke comming out my breather is it because i have forged pistons and they take a while to expand in my cylinders? pls help im stomped.
BigChina
Sep 18, 2008 12:06 PM
y0whuddupb
Feb 7, 2007 01:36 PM
reditr
Apr 3, 2004 08:04 AM
sivic_si
Dec 4, 2002 02:45 PM
