Honda S2000 Honda S2000
Rattle under 800rpm
Old May 18, 2012 | 05:01 PM
GhettoNinja06's Avatar
Default Rattle under 800rpm
Everytime my rpms drop a little below 800rpm I get a rattley noise coming from the front somewhere. Someone told me it is the exhaust gasket that connects the header to the rest of the exhaust (from what I understood). Does anyone know what exhaust gasket to order? Or is it another problem?
Old May 18, 2012 | 05:28 PM
JUSTINTHECOASTI's Avatar
Default Re: Rattle under 800rpm
In all honesty, it could be a lot of things. The best thing to do is to think about what mods you did in the past that couldve caused the new rattle.
Old May 18, 2012 | 07:45 PM
Black S2K's Avatar
how often do ur rpms drop bellow 800?
Old May 18, 2012 | 08:10 PM
Sometimes when I push in the clutch the rpms will drop to about 400-500, makes that rattle noise, then back up to 800. I'll make a vid and hope you can hear the rattle in it.
Old May 18, 2012 | 11:44 PM
bnetkillzone's Avatar
My rattling was the hood, dont have experiences with S2K's but, just try to listen for it.
Old May 19, 2012 | 08:58 AM
Black S2K's Avatar
i think what ur talking about is the noise right b4 the engine stalls. im pretty sure ur fine. i get a rattle too. not sure if its he same as urs but its been like that in my old S and in my current one im not too worried.
Old May 19, 2012 | 02:49 PM
Boots's Avatar
mine seems to only drop that low right after i start it up when the engine is warm...never stalls though and its done it the 4 years ive had the car so i just look at it as an S2Kism
Old May 19, 2012 | 03:05 PM
^My S does that too
I'll make a vid today of the rattling.
Old May 19, 2012 | 03:07 PM
Boots's Avatar
just another quirk of the car it sounds like bro
Old May 19, 2012 | 06:57 PM
alphalanos's Avatar
mine does it too, once you start it the rpm drop almost stall and rattles. then its fine. sometimes it does it twice
Old May 19, 2012 | 07:25 PM
Boots's Avatar
im fairly certain it has something to do with that stupid air pump ****
Old May 20, 2012 | 01:54 PM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
maybe ur engine mount is broken
Old May 20, 2012 | 07:42 PM
Black S2K's Avatar
no way its just the norm. its a extra hard vibration since the engine is about to stal or stall and something rattles for s split second no bigs. almost sounds like a knock
Old May 20, 2012 | 08:19 PM
H22Ej1's Avatar
Shenanigans
generally this super low idle rattle is some portion of the exhaust hitting a heat shield that has seen its better years. those heat shields are made of such cheap steel generally, I'd start there if you are concerned.
Old May 21, 2012 | 05:03 AM
01SSAP1's Avatar
Mine does the same thing its just the S2K's way of saying hit the gas or I am stalling
Old May 21, 2012 | 10:16 AM
Black S2K's Avatar
^ wrong the ecu is constantly learning so if its gona stall u let it stall
Old May 21, 2012 | 01:49 PM
01SSAP1's Avatar
What i meant was if I feel that vibration I know am lugging the engine and the rpm is too low. Same thing happens with any standard transmission vehicle.
Old May 21, 2012 | 10:08 PM
ap1padawan's Avatar
I get the rattle sometimes. I let it rattle. The rattle goes away. the end.
Old May 22, 2012 | 06:14 PM
alphalanos's Avatar
how is this possible when it happens on startup? am i expected to rev it a little to keep it up
Old May 24, 2012 | 12:21 PM
CHONCH2's Avatar
a worn out timing chain tensioner can cause a rattle like this. it's a common thing. look over on s2ki.com for some more info if you can't find any on here. you can either buy a new one that will wear out again, or service your current one, or buy a modified one.
Old May 24, 2012 | 02:06 PM
Boots's Avatar
a worn out timiming chain tensioner sounds like a card in a bicycle spoke...i wouldnt say its a rattle
Old May 25, 2012 | 07:46 PM
It actually does sound like a rattling heat sheild but I checked and didn't see anything loose. I'll look again then take a vid. busy week..
Old May 27, 2012 | 01:46 PM
bigmacnfries's Avatar
Have you got an ETD on there? Mine came loose and rattled like crazy when the revs dipped.
Old Jun 1, 2012 | 03:30 PM
Turns out it was the spark cover..
Old Jun 1, 2012 | 04:01 PM
Boots's Avatar
go ****ing figure lol
