WTB cable gsr trans axels pistons
Im looking for a cable gsr trans b series obviously
Also b series axels to fit in a crx
Also looking for pistons for an ls 81mm=81.5mm and b16 81.5mm
Also engine bearings for both motors and main bearings if you have them acl or oem or whatever as long as there new.. pistons can be used..
Post in here pease bump
I have a cable ys1 with s80 hydro internals 4.4 final drive.
New main shaft bearings and seals. Everything else was clean and inspected to be in working condition. Outside case is cleaned and sprayed silver and clear coated.
$550
Text if interested 323-385-6530
$550
I have a nices set of Place Racing axles made for this exact swap. These are what I ran in mine before I moved up a generation.....check out my link in my sig for details...willing to negotiate price just for the room in my garage!
After math ill talk to my friend and see how much he has. Will u want a ls cable as a core exchange for a little off the price??
do you want the pistons to have rings.
i have some nippon racing 81.5mm pistons. they were installed and motor was started..after a 2 hours of motor running it was taken apart.
They will work ls rods and gsr too...i have them pressed on ls rods..i just need to take them to a machine shop to get them pressed out.
